Glove Box
I need help. I lock my steering wheel all the way to the right which in turn lock my glove box. Here is the thing, now my glove box won't close all the way. It appears as if it is still lock. I can lift the glove box but can't close it all the way. Have anyone encounter this before? Is this a issue or is this the operator? Can someone please HELP?
Glove Box
Steering wheel? ;-) lol
Sounds like you could have a cable out of adjustment. Mine is out of adjustment right now.. but the other way.... won't lock... but I rarely use that feature and leave the key in the ignition anyway.
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
You can't get it to close even though you've unlocked the bars?
'Fly is right... This is an adjustment that the dealer should make...
Had mine do the same thing. The latch mechanism got out of whack, and the dealer had to replace. (it was under warranty) Hope this helps.
Have you turned the bars to the right and tried locking and unlocking the bars a few times? May need to lube the latch.
I would also try using a screw drive to press down on the bottom half of the latch hook as if you were pressing down on the glove box cover to unlatch it.
RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
Member of the WSR (Woodstock Spyder Riders)
Just went through something similar with my 2012 RT_S. If you have the lid open reach down and push the lock latch down with your finger. If it locks and unlocks then it could be the cable as others have said. If the latch doesn't lock and unlock it is broken and will need to be replaced. I just had mine replaced. I locked my handlebars one night the next morning when I unlocked them the glove box wouldn't close after opening. The latch broke for some odd reason.
Tim
I had this happen to me in Maggie Valley. The glove box latch was stuck in the open position and wouldn't close. I'm a little fuzzy on how I fixed it but I remember turning the key to the on position then off and the latch became un-stuck. Don't know why or how that fixed the issue but it works fine now.
Tony
2017 Red F3T
Mods
Lamonster RIP Floorboards
Lamonster H4 LED headlights
Lamonster LED Fog Lights
Lamonster LED White and Amber Fog Ring
Lamonster Show Chrome Fender kit
Lamonster Drink holder
Lamonster Dual Power Plate with large X-Grip
Lamonster F3 Driver Back Rest
Lamonster Lid Lock
Baker Air Wings Luggage Rack
