FOUND A GOOD BUG REMOVER FOR SPYDER
Liquid or spray?
What does it do to vinyl pinstripe tape do you know yet?
Where did you buy it? I had some bug remover made for RVs and it worked good but I ran out and didn't replace it.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Just ordered from Amazon.com. Figured I would give it a try
It has been mentioned in other threads, but, Hydrogen Peroxide works great for disolving the bugs. I am currently using a 50/50 solution with water.
I'm rather partial to Lucas Oil's Slick Mist. I keep a bottle in the frunk. It's a great, quick way to give your bike a nice shine in less than five minutes. I also use it on the windscreen. It makes bug removal easier when the time comes. Also, spraying on bug ridden parts and letting it set for a minute will remove them pronto. ImageUploadedByTapatalk1370658938.016868.jpg
SpyderLovers Sponsor
I tried the 50/50 it was useless in my book it didnt get any bug guts off my window or my spyder unless you putin some elbow grease in it.i bought some stuff called bugs be gone from the auto store now that worked great.sorry just my opinion.and I just washed the bikethis last weekend.
Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
I have found that Bike Spirits Cleaner and Polish works great on all surfaces.
ESCI LED Brake Light, Ram mounts including ATV mount, mug holder and phone/GPS holder. Lamonster's NBV highway brackets. My version of Running Boards, Skid Plate, Bajaron's anti-sway bar, Dual flag bracket and flags. Bad Boy air horn. BRP air deflectors, Non-BRP hitch and USA Minitrailer Nomad, SENA Bluetooth Dongle.
Canada Motorcycle
Here is the link: http://www.canadasmotorcycle.ca/motu...t-remover.html
I use Gater Glo on my Spyder. Just spray and wipe. Works really good on windshield also.
Pro Honda Cleaner is the best I've found and I use it on everything except rubber and leather.
JT
There's no need to dilute the Hydrogen Peroxide. HP is H2O2, basically its water with an extra molecule of Oxygen. Its store in a brown container because after an extend period in daylight it becomes H20 (water).
The peroxide you buy at the drugstore is already diluted...usually only 3% hydrogen peroxide by volume. It makes no sense to dilute it further. If you can find the 6% stuff, even that should not require further dilution. The 30% lab grade peroxide might. Food grade 68% peroxide would for sure.
Invisible Glass
I use Invisible Glass on the wind screen it takes off bugs and leaves a beautiful clear shine.
2021 Sea to Sky, 2013 RT Ltd, 2005 Bombardier Outlander ATV
Originally Posted by Can-Am Poogs
Where did you get it?
Ryde safe,
Rod.
'08 GS SM5 Full Moon -- after 15,000km sold May'11
'10 RT A+C SE5 Full Moon -- after 30,700km traded in 2014
'17 RTL Pearl White -- new-to-me in 2023
"I guess its better to bend a valve in Missoula than to lose your mind in Bozeman", my wife said, patting my hand as if to console me. I winced and wondered if Phaedrus ever took the bus." -Peter Egan, Leanings
CanAm Highway goes from Texas along U.S. Route 85 and Interstate 25 into Saskatchewan, Canada.<http://en.wikipedia.org/wiki/CanAm_Highway>
I get the "Motul" from the bike shop, seems alot of the crotch rocket riders around here use it a lot.
