Gravel? Requires Spyderpops guard
Originally Posted by NHSpyderman
nice idea....pavers or gravel will work good in the spot I picked out !
i would seriously get Harvey's spyderpops gravel guard installed if you decide to put gravel in area used to park..gravel and spyder belt not a good mix..
I do remember reading that-but...
I was thinking gravel to park on wouldn't be so bad- I probably would just roll Spydy onto the pad. Thanks for the reminder though !
You could always lay down a sheet of plywood or two.
Tags for this Thread
