Fox shocks
Folks I have a 2011 RS, I have Baja Ron sway bar and replaced the standard RS shocks with 2011 Rt shocks. Question will the fox shocks provide better performance handling than my current setup now and two what about the pit bull shock relocator does that also provide better handling performance. I do a lot of hard mountain road curves and I'm always looking for better cornering performance
“The only thing necessary for the triumph of evil is that good men should do nothing.” Edward Burke
Speaking from experience I would not buy performance shocks primarily for the purpose of reducing body roll. This is because in order to do this you have to set the shock spring preload so high that it adversely affects ride comfort. I thought I would be willing to give up ride comfort for better handling in the turns but after a year of rattling the fillings in my teeth with every bump I finally gave up and set the preload back to to an acceptable level. Unless your primary goal is to maximize handling in turns at any cost do not purchase performance shocks just to reduce body roll. Instead first use a high performance anti-sway bar and possibly the shock relocators and accept the fact that a little body roll is perfectly normal and does not adversely affect handling all that much. It's only the sensation of the roll that my cause you to back off a bit on turns. For most riders it's just not worth ruining your ride comfort over.
Now with that said, the primary reason for purchasing performance shocks should be better handling over bumps. High quality shocks have much better valving and heat dissipation characteristics so that you will experience significantly better performance when tackling rough roads at higher speeds. You will be able to ride in the worst road conditions with more stability and control. If the shocks you choose have adjustable damping you can further tune the performance more precisely.
So bottom line:
- To reduce body roll: first use a performance anti-sway bar, and possibly shock relocators. If this doesn't reduce the roll enough for you then increase spring preload (you do not need high performance shocks to do this) until you reach the limits of your tolerance for lack of ride comfort.
- If you want significantly better handling in rough road conditions then consider performance shocks.
- To reduce sway in high wind/highway conditions first try a performance anti-sway bar and shock relocators. If this doesn't work enough for you then consider a higher spring preload and performance shocks.
Fox shocks
IMHO- bang for buck, your done.
Personally, I did not like relocated shocks with a stiffer bar...but that's another topic.
I believe the general opinion for the RS is this:
Stock Shocks
RT Shocks
Fox Shocks
Elka Shocks
That said, I don't think you'd see a dramatic difference between running the RT shocks and the Fox shocks. I'm very happy with my Foxes, they do make a difference, but probably not enough to justify shelling out $$$ to go from the RT shocks.
Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
Shocks
I put on the Ron bar and relocators at Spyderfest this year and left my factory shocks on. I instantly picked up 20 mph on any curve I've tried since. I don't think different shocks would be worth the cost for me.
choices, choices..!!
Seems to be a very personal choice. I have seen post from all range of ryders. The ones that see the biggest difference are the ones who fly through the twisties. These would be mostly GS/RS/RSS's. Those who ryde the the RT's in the most part have them for comfort and hauling the kitchen sink. So how much change would you like and what are you willing to give up for it..?? I personally fall in the mid range with an RS two up BajaRon sway bar and highest setting on the OEM shocks with a little more air in the fronts. I like a little roll in the turns make me feel less likely to lose the front end. Jmo To bad they don't have a dressing room for front end set up's to try on...could get costly finding the right one...good luck..!!
2012 RS sm5
Sea Doo GTI-SE 90 Jet Ski!!
I have a 2013 RS and I just put a BajaRon sway bar and end links on and it is an amazing improvement. However they did in 2013 relocated the shocks, which is equal to relocators on an older RS. My opinion is keep the bar, buy the end links, keep the stock shocks and relocate the shocks and ride, ride, ride.......
So bottom line:
Excellent advice!
2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
