2013 owners
The 2013 Spyder catalog shows two grills on the throttle side of the RT one upper and one lower by your foot. Dealer says there is no lower grill anymore just an open space. Is this correct? Thanks
SpyderLovers Founder
There are no grills on the right side of the RT.
Big Rig Member
BRP's web site shows the grills also. If you look at the RT Limited pictures on the web site, it shows both with webbed grills.
Motorbike Professor
Those are illustrations, not photographs. Chalk it up to the artist's imagination.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
On my first spyder I panicked one night when I thought I had lost a grill like part on a nearly new bike.. Only later I found out the part was never there - even though when I called the dealer I used back then, they initially told me they would order the replacement part for me...
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
Do you mean the accessory catalog? Or the Spyder brochure? I can't find a good illustration or photo of that part of the RT in either one.
The 2013 Spyder catalog , not the accessory catalog, shows a yellow RT-S with a lower right grill. There are holes for a grill on the right which are reverse of the left side. Turning the left grill upside down might fit the right. Anyway I thought the dealer had lost mine and was pretty upset. Called them back and admitted they were were correct. I do not know why they omitted a grill on the right unless it had something to do with radiator cooling.
BTW Thanks Lamonster for the quick reply.
Good Reason for No Right Side Grill
I think they decided to omit the grill so your ankle would start to cook faster if you decided to start resting your right foot out on the lower fairing instead of near the brake lever. <smirk>
2013 owners
No grill for top or bottom on 2013 RT.
Cruzr Joe
