Results 1 to 16 of 16
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    Default SE5 and downshifting, ProCaliber Longview & PitBull Powersports.....
    I have always had a problem with downshifting and apparently, didn't know it! The bike (exaggerated in tow mode) has always surged forward terribly when down shifting! It was scary some times in curves and while riding two up and towing a trailer, the downshift surge would scare my wife as well as engage the ABS. I always assumed it was the way it was supposed to be but was always curious why nobody has ever complained on the forum about the surge. This week the bike went into Procaliber Longview and when Shawn took it for a ride he said the clutch plates are not disengaging as they are supposed to do. Now keep in mind, this bike has done this for 19,000 miles. Shawn called BRP and they said my warranty expired on 5/11/2013 and it was too bad! Shawn did not stand for that and argued with them that I explained this issue on 4/23/13 at Spyderfest. BRP has conceded and agreed to cover the costs of replacing the clutch and I have Shawn & ProCaliber Longview to thank for it. This dealership and tech consatntly goes out of their way, above and beyond, to stand behind the customer! Too bad it will take 5 business days to get the parts.
    On the ride home from Spyderfest, I discovered that the left front tire had warm smooth on the outside and the bike handled like a pig. I had Pitbull Powersports install shock relocators at the event and Shawn discovered that one had been installed incorrectly which put the front end way out of alignment! Shawn was able to very easily correct the install and Len at Pitbull was very willing to compensate me with covering the replacement cost of one of the front tires. With all this said ... I am very interested in seeing how the bike shifts (as it should have always done) and how the bike handles with the shock relocators properly installed. I have not been happy with the handling since I had them installed but have withheld public judgement since everyone has loved them!
    I cant wait and once again ... KUDOS to Procaliber Longview, Shawn, Len and PitBull Powersports!!
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    I installed my relocators and can't help wondering how you install one wrong? Did they say what was wrong?
    JT
    Active Member schnauzermom's Avatar
    May 2012
    Renton, Wa
    Default PROCALIBER THE BEST
    DITTO!!!!! Last summer my husband and I became stranded when the throttle body went out on my 2011 RT SE 5. We found ourselves about 30 miles away from Procaliber in the mountains and gave them a call. We were on vacation about 2hrs away from our RV and our 3 schnauzers. Procaliber came and towed us and the RT to their shop no charge. We met Shawn and soon realized we were in great hands. After our parts arrived 4 days later, (we had to rent a rental car to get back to our RV), the RT was like new again and even though they weren't our local dealer we were wishing they were.
    Sent from my KFJWI using Tapatalk HD
    Registered Users joet82's Avatar
    Oct 2010
    Winlock, WA
    Best 2 dealers in the nation, imo
    RS - 55K+ miles, F3 - 200 miles and counting.
    Invalid Emails
    Oct 2011
    Glennville, Ga
    I have a 2010 RS and it has always surged, especially going from 3rd to 2nd. I just thought it was normal.
    Default RE-LOCATORS
    Quote Originally Posted by jthornton View Post
    JT
    x 2.....Mike...
    A couple dealers who truely believe in customer service.
    May 2013
    Battle Ground Washington
    Default Good to know
    I just bought a 2012 RT-S SE5 from SK northwest in portland and I live in Battle Ground WA its always good to know where the good dealers are around me. I have had a good experience so far with SK but its always good to know others around me.
    Registered Users SpyderWolf's Avatar
    Oct 2009
    Martin, SC
    Thanks for the report on this and I am very glad to hear you had a good dealer stand up for you. Hopefully your Spyder will be back on the road very soon and you will find out how smoothly it should have been shifting all along.
    Quote Originally Posted by Daisyjoe View Post
    The surge is not normal. It may happen at times when you are in need of an oil change the clutch is not disengaging properly, but if it does it all the time you may want to get it looked at. Of course, this is assuming your hand is completely off the throttle when the downshift occurs. If you are still on the throttle somewhat and hit the magic downshift range of 2400 RPM or so that will also cause the surge. That is why many of us like to downshift ourselves and be in control of when it happens.
    Very Happy Spyder Ryder!
    Click here to see My Spyder Mods
    Mar 2012
    Beaverton, Oregon
    I guess there are three bolts holding the relocator in place. One bolt was fine and the shock could go nowhere but on the front two bolts, one goes thru a hole. It missed the hole entirely, essentially raising the one side about 10mm higher than the other. I don't hold this against PitBull because of the overwhelming crowd that descended on their dealership during Spyderfest! Something was bound to go wrong somewhere!
    Here are some pics of what was found
    Mar 2012
    Beaverton, Oregon
    Well here is the followup:
    I picked up my bike yesterday. It is a "new" bike. The handling, performance & shifting are all amazing! I still cannot believe I have ridden that bike 19,000+ miles without the clutch ever fully releasing!
    Here is what was done:
    14,000 mile service including:
    • check BUDs for codes - none
    • adjust valves - yes, needed done
    • replace spark plugs and wires with BajRon / Accel/NGK
    • check crankcase vent
    • check fuel filter
    • check exhaust system
    • reset Idle speed with BUDS
    • synchronize throttle bodies
    • replace air filter
    • drain, flush and refill coolant system
    • replace engine/transmission oil and filters (Amzoil)
    • check clutch operation (found clutch not releasing completely)
    • check transmission shifting (verified shifting issues)
    • grease Zerks and A arms
    • adjust drive belt
    • check steering
    • check suspension (found one shock relocater installed wrong - corrected and readjusted Elkas for sway bar and relocator)
    • flushed brake system
    • checked brake pads - 70 to 75% left at 19,00 miles
    • checked wheel bearings - tight and free wheeling
    • checked tires - see below
    • checked all electrical
    Not in 14,000 mile service but covered under warranty:
    • checked alignment - was fine after shock relocator install correction.
    • installed two new front tires (one was warn out result of shock relocator installed wrong)
    • installed new improved heavy duty clutch pac. - looks like a BRP racing clutch
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by bmwlarry View Post
    I could not even picture in my mind one getting installed like that without seeing the photos. Thanks for sharing. Do you still lean by habit when riding the spyder?
    JT
    Very Active Member daveinva's Avatar
    Mar 2011
    Washington, D.C.
    • check fuel filter
    • adjust drive belt
    • check steering
    Larry, since we've been on the subject in numerous threads lately, how much did your 14K service run you, if you don't mind sharing?
    Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Probably 2 hours labor just to write it up
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Oct 2009
    Martin, SC
    Glad to hear they got everything sorted out for you.
    Mar 2012
    Beaverton, Oregon
    I had them use my own oil, filters, o-rings and washers, I supplied the plugs and spark plug wires and Pit bull covered the cost of one on the tires. Clutch was covered under warranty.
    14,000 service with valve adj., using my provided oil change supplies: $599.99
    new tire with install: $100
    ride on in tires: $30
    happiness: PRICELESS!!
