Originally Posted by HuckFin
Success. Actually downloaded my first pictures. I tell you, there has to be a better way....I had to e-mail them first to my daughter so she could compress them somehow to send back to me. Then figure out how to put them in my files.
How many inches of rise did you get?
2014 Silver Platinum ST Limited: Mods so far: fog lights, passenger backrest, ultimate seat w/driver backrest, rivco drink holder bracket with ram x-grip cell phone holder
Tea is very good,i would like to know how many inches rose and if it is easier to operate, and with less effort than with the handlebar of series
2 and 1/2 inch rise (measured from top of forward bolt holes to top of handlebar center)
sebastiano: I have not had the chance to ride the spyder yet. Its been raining for the past two weeks but I expect it to operate the same. I will just be sitting in a more upright position.
Bar replacement
Here are the pictures of the STS handlebar on the RSS.
How much did that raise your bars if you can tell in inches?
Did a dealer give you the advice or where did you get the idea those bars would fit? My dealer told me those bars would not work on my machine which is virtually the same machine you have, a 2011 RSS.
2013 RS-S to ST-S Handlebar switch
They probably won't work on your bike. The 2013 RS has different handlebars than 2012 and earlier RS/GSs. The 2013 RS bars are lower than the ST bars, but nearly identically styled.
2013 RS-S SM5 [His] • 2021 RT Base [Hers] • 1977 Bultaco custom roadster • 1974 Harley-Davidson/Aermacchi 350 SS
I want to switch my RS-S handlebar to the ST-S handlebar...
Do you have any plans for your RS handlebar? I have an ST-S and was contemplating going in the other direction.
Read post #11 on my opinion if 2013 RS-S bars will fit earlier spyders or not. Afraid your on your own, I don't know if anyone has tried to go that route yet.
I replied to your PM.
Did you get rid of your RSS bars? If not I would like them to put them on my 2013 ST-S.
Thanks,
Carl
2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
Thanks,
Carl
They are already sold. I sent you a PM. Thanks. Larry
replacing my 2013 RSSE bars with ST-S bars
Can you tell me if you had any problem with the original throttle cable length when you switched to the ST-S bars
I want to switch my RS-S handlebar to the ST-S handlebar. I have talked to BRP and local dealer, they both say they should bolt right on, but they don't know if the plastic center steering cover. (fits in front and below center handlebar and covers ignition switch) will bolt to the bottom of the ST-S handlebar....So I'm hopeing I am not the first to try this and if there is someone out there that knows. Also RT handlebar should bolt on too...I am talking 2013 here, earlier bars are different....Oh, one more thing....Could the ST-S plastic center cover work instead?
Welcome to the site .
2013 models don't have throttle cables they are throttle by wire
Bill
2013 RSS Neutron Green
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
Bajaron sway bar and links
it was fun while it lasted.
did you end up replacing the Steering Central Cover or did the old one work with the new bars?
