I haven't seen this one posted on here yet. I trie out a new mod with my 2009 RS to try to help with the heat issue as well as the exhaust smell I get from my touring windshield an wind deflectors. I noticed on the 2013 ST it had a heat shield between the left and right side panels and the body which is currently open on the RS. You get a lot of heat coming up through these openings at your body, legs, and face. I decided to try and fit these to my bike so I ordered the 3 parts from the can an store. Around $90 for the set. The fit really well. I had to do a slight cut on the top of the inner plastic on the side with the fan since the shroud covering the fan is deeper on the newer model. Rose 350 miles today and it did great! Eliminates the heat coming up at you and forces more out of the side eliminating the heat at your foot also. Did mot affect the running temperature of the bike at all. Here is a few pictures after the install. What do y'all think?
2014 Silver Platinum ST Limited: Mods so far: fog lights, passenger backrest, ultimate seat w/driver backrest, rivco drink holder bracket with ram x-grip cell phone holder
Are the panels still easy to remove and put back on with those in place? Definitely let us know how it works when it gets much hotter out, as I may do the same thing to my wife's Spyder if it works well. Thanks for sharing.
Awesome Job.... And Looks like it was supposed to be like that from the factory!
2013 ST-S SE-5 ("Quick Silver") Is her Name
My Mods: I Have Added the AM/FM Stereo and an Ultimate Seat, with Ryder Backrest, Power Sports wraps." Break Strips" Kit, GloRyders with the Spyder Cap, Fox Racing Shock and Anti- Sway Bar Kit, Spyder Pops Bump Skid, Spyderlighter's LED Running Light Kit With Fender lights. Cal Si Shorty Smoked Windshield, The 2014 Side Panels, Lamonsters Cat Delete, And an Akrapovic Sport Touring Exhaust.
Panels still remove like normal. Funny thing is there's only one bolt hole that's not on the older spyders that is needed to mount and its not actually needed. Right side is simply removing the old shroud that's bolted into the side panel that forces air from the radiator out the side opening and bolting the new one in. The other side just snaps over the oil reservoir and bolts to the existing hole that sticks out from the side of the oil reservoir. Here is a picture of the oil side.
Read this late night and since i was going in for an oil change, I ordered a set to see if it will work. Thanks for the heads up Rx.
it is what it is - 2014 Black RT-S - Baja Ron Anti-Sway bar, lots of LEDs, Spyderpops Skid Plate, Twisted Sister HID Driving Lights, Tricled 2nd, 3rd & 4th brake lights, F4 Customs vented windshield, Lamonster highway pegs, Ultimate Tall Boy seat, Utopia backrest
Let me know how y'all think it works. I've been satisfied so far. Definitely doesn't solve the problem completely but does cut the hot air coming up at your face. The only downside I've seen is the new scoop does force a lot more air out the side. I have rivco highway pegs so this puts a lot of hot air on my right foot when using the highway pegs. Not unbearable though.
