Results 1 to 20 of 20
Thread: What car tire?
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    Default What car tire?
    Ok so I'm going to get new front tires. Which tire should I get for the front of my rs that doesn't require any modding of the fenders. I have looked at the potenza tire but are there other options or should I say better options from y'all's experiences. Thanks in advance!
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Apr 2011
    GREENVILLE, SC
    Default KUMHO
    check out the KUMHO http://www.kumhotireusa.com/
    I've got KUMHO's @ all 3 corners, and couldn't be happier....
    Jun 2012
    Brandon, MS
    Quote Originally Posted by SPYD3R View Post
    I noticed they don't have a 165 tire so what size did you get?
    Default Many threads..!!
    you could read through the many threads on tires. At this point it seems that as long as the tire size matches they will work. A thread should be started with a list of the brands used. I have seen :Falkens, Yokohama, Kumoho and a few others. I would prefer to keep all three tires the same. Jmho...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Invalid Emails
    Ormond Beach FL
    Default You just created a new industry position
    Quote Originally Posted by Mr Orange View Post
    That's becoming the tricky part and if you check what's available for the new 15" ST Spyders it becomes downright impossible. Now if only they went to a 16" or 17" wheel at all 3 points it would be a whole different story.
    I think you may have just created another niche industry special wheel sizes. Now all we need is someone to create a reliable odometer conversion adapter niche market.
    Jun 2011
    Near Lexington, NC
    Default Can Front wheels be balanced on standard auto shop equip?
    Most shops have the "standard" spin balance machines; does the Can Am front wheels fit on these machines?
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    SpyderLovers Sponsor scooterexpress's Avatar
    Mar 2012
    ft-worth texas
    i put on yokohomas 175/65r14 65k mi warranty. needed no modding of the fender.got them at discount tires for 88ea.
    Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
    Sep 2011
    North Plains, Oregon
    Quote Originally Posted by scooterexpress View Post
    Out side of longer tire wear, Do going to Car Tires make the bike handle any better?
    Jun 2012
    Brandon, MS
    I am assuming that the 175 VS the 165 does not affect the computer at all correct. I just ordered the Yokohomas
    Very Active Member mike3069's Avatar
    May 2008
    Saratoga Springs, NY
    Quote Originally Posted by Spyder12 View Post
    In a word, YES!
    P.S.- I put on Faulkin ZE912's, no mods needed. 20k miles and still going strong.
    The glass is half full.
    Mike Murphy
    Happy Spyder Owner
    Bryant, Arkansas
    Yes i had my 14 inch rt wheels balanced at a local tire shop, they can do a dynamic balance or a static balance (static balance requires less weights)
    Cruzr Joe
    Quote Originally Posted by mike3069 View Post
    In a word, YES!
    P.S.- I put on Falken ZE912's, no mods needed. 20k miles and still going strong.
    I've got a ZE912 out back; did you find a 165/65-15 ZE912 for the front? Where?
    May 2008
    No, I had to go with 175, but no mod required (it JUST fits)
    Mike Murphy
    Happy Spyder Owner
    Very Active Member kinggeek's Avatar
    Jun 2011
    Cincinnati, OH
    General Altimax HP 185/60 R14 Installed no mods to the fenders required. Love them!
    Kinggeek
    Mandeville,LA
    VERY HAPPY Spyder Ryder!
    Where have we been on the Spyder? See below:
    Can-Am Spyder ST-S SE5 in Congac
    Cool! Thanks!
    So now you're also going out to the shop just to "Check the air in those Falken tires; one more time!"
    Jan 2013
    Las vegas
    I just called Discount tires in Vegas they can order either bridgestone or Michelin tiires that are the same size for the RT which is 165-65-14. Therefore, no additional work is required.
    Feb 2013
    Morris,mn.
    Default Best rt rear tire
    I heard Michelin has a good 4 ply rear tire that would last much longer than original tire. Has anyone tried Michelin?
    Jun 2012
    Brandon, MS
    Getting these tires mounted tomorrow what air pressure do u run these at?
    Mar 2012
    ft-worth texas
    Quote Originally Posted by Spyder601 View Post
    i put 20psi in but i may reduce to 18psi at 20 to me seems a bit squirrely,but i may need to adjust my elkas instead i really don't know what the true answer is in this situation.oh i also put ride-on in for protection and balance no weights on rims rides very smoothly.
    Jun 2011
    Near Lexington, NC
    Start about 18 or less. I run 15 on the OEM fronts and 22 on car tire rear.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
