Results 1 to 10 of 10
    RT-S PE#0134 glynnk's Avatar
    May 2009
    Cypress, Texas
    Default 2010 RT-S Brake Failure
    Got a "brake failure" flashing orange screen along with the red "!" icon. In checking the codes, it's throwing C1282. Parking brake and brakes work. Anybody know what that is or where I could find the answer?
    Glynn
    Happy 10 RT-SPE owner!!
    You may have low brake fluid. I have experienced the dreaded orange brake failure screen when going down a very steep incline. When I got the leveled off no problem. Checked out brake fluid container and it was low a tablespoon or so.
    Hope its something simple like this to get your problem solved.
    May 2009
    Cypress, Texas
    Default RE: 2010 RT-S Brake Failure
    Thanks. Level appears fine. Dealer indicates code suggests excessive brake travel and possible air in lines. Any thoughts/comments?
    Sent from my RM-845_nam_vzw_100 using Board Express
    Nov 2012
    North Las Vegas, NV
    Fill brake fluid to top with DOT4 fluid. It doesn't take much to set off sensor, mine did it on the way home from picking up the spyder. If that doesn't do it then bleed the brakes.
    brakes.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Mar 2008
    Allegan, MI
    C1282 = Brake Failure, low pressure detected
    Most common cause is riding the brake pedal without actually putting pressure on it. Sometimes this can be cause by accumulated debris. It can also be caused by an improperly adjusted brake switch, a failed sensor, or an actual loss of hydraulic pressure due to a problem in a caliper or master cylinder. It could also indicate severely worn brake pads. Be sure you are not touching the brake pedal, be sure there is nothing lodged between the pedal and return stop to prevent its full return, and be sure the switch is not clogged with debris and that it has a tiny bit of free play before engaging. Inspect the brake pads. You cannot do this visually, as they are very thin anyway, they really should be measured. Minimum thickness is 1 mm. Beyond all this, see a dealer ASAP. If it is a hydraulic problem you could lose your brakes altogether quite suddenly.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Default Can't Help..!!
    never can add much once Scotty has spoken..!! Good luck, the man knows his stuff..!!
    ​2012 RS sm5
    Very Active Member GeoffCee's Avatar
    Dec 2010
    Telford, UK
    Quote Originally Posted by NancysToy View Post
    This happened to me. I was riding with my foot covering the brake pedal during an "interesting" ride on some very twisty Spanish back roads in the company of several 2-wheelers. I didn't know my foot was inadvertently touching the pedal and when the brake failure message lit up it came as a hell of a shock! A lesson not to be forgotten.
    2011 RT-S SE5, Acumen Tempest Cat-1 Alarm, SmoothSpyder Belt Tensioner,
    Autocom Super Pro Auto, Garmin Zumo 550 BT, 10amp Socket, Front Fender LED's,
    Grip Puppies, Spyderpop Belt Guard, Nautilus Horn, Shortee Antenna, BajaRon's Swaybar,
    Cree LED Day Running Lights.
    Invalid Emails
    Ormond Beach FL
    Default A typical newbie trick
    Quote Originally Posted by GeoffCee View Post
    This is a typical newbie happening . Apparently the grumpy computer can sense your foot covering the brake pedal even if you are but not exerting enough pressure to activate the brake lights. I did the same one night ride in the first week of being a Spyder owner. Now I just stop and take my right foot and move it to the right and the computer is happy. Nothing beats a happy computer, right ?
    but love that stopping power moves the wife up real close!!! To bad they were not making them in the sixties when I was single and dating.......
    Dec 2010
    Telford, UK
    Quote Originally Posted by Bob Ledford View Post
    ...but love that stopping power moves the wife up real close!!!
    You mean it doesn't flash up a failure code when your load slides out of position? I'm SHOCKED!!
    Registered Users RTVIPER's Avatar
    Jan 2012
    El Mirage, AZ
    Default BRAKE FAILURE FAULT CODE C1282
    I keep getting the brake failure when taking the out of park to put in gear. Bringing my 2011 RTS-SE5 back to the dealer, for a 2nd time, to check this. Happened to me again last night.
