Re: Aaaaaagh!!!
It has gotten a lot of us. Now that its happened to you, You will remember from now on.
Sent from my SPH-L710 using Tapatalk 2
SpyderLovers Sponsor
Or... Someone did you a 'Favor'. Beware of this at Spyderfest.. Just a word to the wise.
Check for neutral first then kill switch.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
Motorbike Professor
Originally Posted by muleman1
Out for a nice ride this afternoon and stop for gas. We go to leave.....and the won't fire up!
Five minutes later (mulemanskatie even gets out the manual)....I finally think to check the dreaded "red button of death".
Apparently "someone" bumped it while dismounting. WHEN will I start checking for that first instead of last?????
You will start checking it first when you learn to shut off the Spyder using the kill switch. If you do that, it becomes second nature for shutting down the engine in case of a serious problem, and it becomes the first thing you do after you turn the key on.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
This kind of goes back to the basics....
F.I.N.E - C
Fuel
Ignition
Neutral
Engine cut off
Clutch
Honestly, those of you that don't use the cut off switch for shut down, should really work on using it. It's a good habit to get into knowing that switch without thinking of it...
F.I.N.E - C
Fuel
Ignition
Neutral
Engine cut off
Clutch
I'm afraid of wearing it out!
Red 2016 RTS, Diamond R Armrests, Ram X Mount, Doc Humphreys Dampener, BajaRon Swaybar, Spyderpops "Critter Splitter"
"It is the common fate of the indolent to see their rights become a prey to the active. The condition upon which God hath given liberty to man is eternal vigilance; which condition if he break, servitude is at once the consequence of his crime and the punishment of his guilt." John Philpot Curran 1790
For sure..!!
Even those who don't admit have had it happen. The thing is how long it takes you to figure it out..!!! Rest assured it will happen again but you will figure it out right away..!!
2012 RS sm5
GOS member (Girls On Spyders)
I haven't done that since I use the kill switch to shut the bike off... BUT... the first time starting it after this winter, I went through my mental checklist. Waited for the computer to boot-up and hit start and nothing. Absolutely nothing.
Same feeling... what the heck is going on? Battery under-charged? What is it?
I sat there and stared at the screen trying to figure out what is wrong... until it dawned on me to hit the mode-button.
SL #7026
VBA #652
HOG #3935417
2011 Viper-Red Spyder RT SE5 & Trailer
2017 HD Ultra Limited
Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
Adult beverages
I found it can take longer to figure out after a few adult beverages.
Don't just dream the dream! Live the dream! Sent from my coconut using tap-a-nut. Spyderlovers Southern-Most Member.
After spending the last 30 years riding snowmobile, I use the kill switch all the time.
That mode button will drive me insane though..........
Just sayin'............
Three in the garage, and I think I can fit at least one more in.....and then we will have to build another garage.
The roads in NY are so bad that I am glad we bought a Ryker Rally
Yup, guilty. Also, on the first ryde away from home, I forgot to step on the brake, and had to call a neighbor for starting instructions! And YUP, it was with my HD buddy... in fact HE made the call!
But now at 2,7xx miles I've gotten into the habit of immediately setting the kill-switch back 'on' as soon as the engine dies. I use the kill-switch to keep the display turned on, so I can review a couple screens first... stuff that I shouldn't be doing when my eyes belong on the road.
R U Saying?
That there are practical jokers amongst the Spyder Community?
if it were to happen to me I would scream, "Harley Davidson terrorists!"
F.I.N.E - C
Fuel
Ignition
Neutral
Engine cut off
Clutch
And for the shut down it's Thumb Key Valve. Spyders skip that valve step of course so, I guess we could make it Thumb, Brake, Key.
-Christina
2012 RT-S Blue
Photographer and horse rider.
