Add Oil
Last oil change was done at dealer using the BRP oil on my 2010 Roadster SE-5. Does it hurt in anyway when it comes time to add oil to use a different brand such as Amsoil MCF?
Amsoil MCF 10w40 would be a fine choice. But 20w50 absolutely not.
Motorbike Professor
Most oils are compatible these days. You should not have any problems. The safest route would be to use the identical oil to top things off, however.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
I use amsoil 10w40 and had to top off and all they had was a differant oil .....ran fine and being an ase auto Tec was not to concerned. Go Ohio
Remember to check the oil when it's at operating tempature.
Mike
Remember..!!
stick with similar type and weights, synthetic, semi or synthetic blend or regular, 5w-30 or 10w-40. If in a bind they will work fine...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
2010 RTS-SE, Orbital Blue
I dont know if it still makes a difference, but years ago, it was not recommended to mix eastern oils(Pennsylvania paraffin base) with western(carbon based)oils. I don't know if this is correct or not, but I still usually stick to the same brand.
Can be mixed.
The following is from the Amsoil FAQ's.
