Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    Default As I see it..!!
    from reading past history, most of the hoses failing are from those with the harsh climate changes and stored units. In those areas and conditions the silicone hoses would be a good idea. Really glad you found the problem and the advise given was helpful...
    ​2012 RS sm5
  2. #27
    Registered Users vendit's Avatar
    Jul 2009
    Dewitt, Michigan
    Default Vacuum hoses
    Where are these vacuum hoses located? Left or right side of bike? What Tupperware has to be removed to get to them?
    thanks!
    Just remember: "It will feel better when it stops hurting!"
  3. #28
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    Left side Tupperware has to come off hoses located on left side of throttle body.
    Sent from my HTCONE using Tapatalk
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
  4. #29
    Active Member GadgetGuy442's Avatar
    Jun 2010
    Brighton, MI
    Default Rough Idle, Check Engine then Limp Mode after Storage
    I'm going to check my vacuum lines for sure now!!
    One other thing that is good preventive maintenance to do is to excersize electrical connectors and use dielectric grease to prevent corrosion.
    For every electrical connector you can get to, separate the two halves and re insert them together 4 or 5 times. Then separate one more time, and put some dielectric grease in each of the female terminal recesses, then reinstall.
    This saved me from a throttle body replacement that the dealer was instantly ready to do, when all it turned out to be was a corroded terminal. HAVE PUT TWO THOUSAND TROUBLE FREE MILES ON MY 2010 RTS SINCE THEN, so am pretty sure I didn't need a new throttle body!!
    It's worth a try, IMHO.
    Bill
  5. #30
    Feb 2012
    San Jose California
    Great information here.
    I am having P1172 code, I guess it is the vacuum hoses (RT 2012).
    I was able to get the back one out easy, having hard time with the front one since it is stuck pretty hard.
    Any tricks how to get it out (heating, cutting....)
    Thanks
    This message was sent between rides
  6. #31
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Quote Originally Posted by szohar View Post
    Thanks
    I ended up cutting it off with razor knife.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
  7. #32
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    Same here. I bladed them off.
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
  8. #33
    Feb 2012
    San Jose California
    Hi,
    I replaced those two vacuum hoses took it for a 5 minutes ride but still getting the check engine and the P1172, bike is under warranty but dealer is 94 miles away (it will be a waste of two days for me and my wife).
    Any ideas will be welcomed.
  9. #34
    Nov 2011
    Ponciana
    Keep this one on hand
    Sent from my SM-G860P using Tapatalk
  10. #35
    SpyderLovers Sponsor spidergreg's Avatar
    Sep 2015
    Jamestown, KY
    Default Just changed out hoses
    I got a 2012 RTS and got the P2279 code, changed out the hoses and all is well. It was a bit hard finding the front hose, removed the wire ties on the harness and was able to find it. My NAPA store only had the H458 and not the H466 silicone, so I replaced with the EPDM rubber this time. Will order the H466 for next year. Have to wonder why BRP doesn't use the silicone in the first place!!!
    Greg and Debbie 2012 RTS
    Our Mods
  11. #36
    Jul 2019
    Pennsylvania
    Default 2013 sts
    Mine is sending same codes . Could it be my hoses
Tags for this Thread
