Vacuum hoses
Where are these vacuum hoses located? Left or right side of bike? What Tupperware has to be removed to get to them?
thanks!
Just remember: "It will feel better when it stops hurting!"
Left side Tupperware has to come off hoses located on left side of throttle body.
Sent from my HTCONE using Tapatalk
2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
Rough Idle, Check Engine then Limp Mode after Storage
I'm going to check my vacuum lines for sure now!!
One other thing that is good preventive maintenance to do is to excersize electrical connectors and use dielectric grease to prevent corrosion.
For every electrical connector you can get to, separate the two halves and re insert them together 4 or 5 times. Then separate one more time, and put some dielectric grease in each of the female terminal recesses, then reinstall.
This saved me from a throttle body replacement that the dealer was instantly ready to do, when all it turned out to be was a corroded terminal. HAVE PUT TWO THOUSAND TROUBLE FREE MILES ON MY 2010 RTS SINCE THEN, so am pretty sure I didn't need a new throttle body!!
It's worth a try, IMHO.
Bill
Reason: typo
Vacuum hoses
Great information here.
I am having P1172 code, I guess it is the vacuum hoses (RT 2012).
I was able to get the back one out easy, having hard time with the front one since it is stuck pretty hard.
Any tricks how to get it out (heating, cutting....)
This message was sent between rides
I ended up cutting it off with razor knife.
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
Same here. I bladed them off.
2017 Can Am Commander Limited
2012 Cadillac CTS-V Black Diamond
2020 F3 Limited Magma Red (miss the 2011 Viper red)
2010 RT622 - Black
Vacuum hoses
Hi,
I replaced those two vacuum hoses took it for a 5 minutes ride but still getting the check engine and the P1172, bike is under warranty but dealer is 94 miles away (it will be a waste of two days for me and my wife).
Any ideas will be welcomed.
Keep this one on hand
Sent from my SM-G860P using Tapatalk
SpyderLovers Sponsor
Just changed out hoses
I got a 2012 RTS and got the P2279 code, changed out the hoses and all is well. It was a bit hard finding the front hose, removed the wire ties on the harness and was able to find it. My NAPA store only had the H458 and not the H466 silicone, so I replaced with the EPDM rubber this time. Will order the H466 for next year. Have to wonder why BRP doesn't use the silicone in the first place!!!
2013 sts
Mine is sending same codes . Could it be my hoses
Tags for this Thread
