Baker Built Belt Tensioner
Installed the new Baker Built Belt Tensioner on wife's RT yesterday, very easy install. Remove belt guard (Torx bit #27) for access, remove 15mm nut on lower shock bolt, install kit, put roller on and center on belt, re-check all bolts for tightness. Test drive to verify roller is aligned on belt, re-install belt guard.
belt tensioner 1.jpg belt tensioner 2.jpg belt tensioner 3.jpg belt tensioner 4.JPG
Thanks for the Pics!
Kagey
Do not mess in the affairs of dragons, for you are crunchy and taste good with ketchup.
Spyder RTS SE5 - Quantum Blue Metallic - LED RT HMT Brake Light W/Dual Converter Unit - Lamonster NBV Highway Pegs
SpyderPops "Missing Belt Guard" - "Butt Buffer" Butt Pad - Utopia Backrest - Original Grip Buddies - Digital Volt Gauge
Analog Clock - Shark LED Light Kit - BajaRon's SwayBar - Mud Flap - Custom Dynamics Radiator Inlet Covers
Seal FloorBoards - Baker Air Wings - SpyderPops BumpSkid
My little test ride to verify roller alignment indicated that it works as advertised. This is my wife’s ride so I cannot speak to any of the performance issues as weather has not permitted us to get out on a performance run.
Feed Back
Feed back would sure be helpful.
Looks good and good pictures
2012 Spyder RT SE5 Brake pedal mod
Belt tensioner
I would really like to hear back after you get to try it some more if it reduces harmonics in the drive belt.
Where did you get it? I don't see it on the Baker Built website.
Where did you get it? I don't see it on the Baker Built website. http://www.bakerbuilt.com/bbairwings/page126.html
Great job..!!
good pic's and install explanation. We have the smoothryder and it works well. Little more involved in the installation. Will have to see feed back on yours..!!
2012 RS sm5
