Results 1 to 21 of 21
    Apr 2012
    Columbus, Ohio
    Default Muthco Turn Signal Mirrors
    Anyone purchased mirrors that have the enclosed turn signal light in the mirror. I was looking at this and thought what a neat idea for the RT. I think they install them for 219.00 per mirror. Does anyone have these and if so was or is it a good investment?
    Thanks
    Ron
    I'm cuious as well...
    I'm pretty sure that at least one of us did get a set of them; they posted pictures of them in here during all of the discussions about extra turnsignal indicator lighting...
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    I have them on my Goldwing & LOVE them! Have been thinking about getting them for the RT...
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
    Muth.jpg Here's the picture that was posted in here...
    Default Good looking..!!
    Used button lights on the dash on my RS but these look fantastic..!!
    ​2012 RS sm5
    washington state
    Another mod for safety not just furkle.it's worth having.
    2012 Spyder RT SE5 Brake pedal mod
    That's how I slid my project past the Missus!
    Jul 2011
    PA
    I had them on my Gold Wing and they are great. My passenger loved them as she could see what turns I was going to make before I made them. When I mounted LED strips on my RT mirrors, Muth did not have anything available for the RT's. I wrote and told them they should develop a kit for them just like the Gold Wings. Many others must have done the same. It looks like they have developed a kit for the RT's.
    However, the 'Wing is a simple replacement -- easy to take out the mirror, put in the mirror, wire it and you're done. Very simple. I just took a look at the "instructions" on the Muth site for the RT. They require you to disassemble the mirror housing (tricky at best), then heat the mirror glass with a glue gun to soften the glue and separate the glass from its backing, etc, etc. Not a job I would want to tackle. If you could ship them the complete mirror and get it done by them, great. But it looks like for $219 they send you the kit and instructions. For $20, my LED strips look very built-in and work great. There are numerous threads here detailing different approaches by folks using arrows, LED strips, etc. Muth would give you the most professional OEM look, I admit. But you might want to take a look at the instructions first. If they make you uncomfortable, give them a call to see if they would do the installation. Just a suggestion...
    RT and Gold Wing States & Provinces
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    For about $7 you can buy surface mount LED turn signals at the autoparts store and wire them into the factory signals on the front side of the mirror housing.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    Active Member crazyspyder's Avatar
    Mesa , arizona
    Default muths mirrors
    Quote Originally Posted by gypsy_100 View Post
    you can shipp your mirrors to them and get the installment done thru them -I believe they told me about 260.00..its called S-MOD install on their website!
    '' RIDE -WINE - DINE LIKE ITS YOUR LAST DAY- SO MAKE IT COUNT DAILY''
    2013 ram 1500 RT HEMI 405 Hp
    2012 spyder RT + cat-bypass, mod muffler, PCV + auto tune, HID headlight n foggers, seal floorboards, LED's every where, supercharged ..not!
    2012 Fiat c500 conv.
    Thanks for that info!
    It's pretty obvious that this is a relatively expensive way to attack this issue; but the results do speak for themselves!
    May 2009
    Connecticut
    Quote Originally Posted by DR Buck View Post
    For $20 at AutoZone and 4 Positaps you can have rear AND Side visibility.
    Sea Doo GTI-SE 90 Jet Ski!!
    Registered Users Dragon Snake's Avatar
    Mar 2011
    lake city michigan
    Quote Originally Posted by Sarge707 View Post
    Do your lights act as turn signals and running lights?
    May 2009
    Connecticut
    Quote Originally Posted by Dragon Snake View Post
    Only Turn!! Same as the other Turn Signal Mods?
    Jul 2011
    PA
    Agree. That's what Muth will do as well.
    Registered Users Spyderific's Avatar
    Jun 2012
    Alberta
    Tricled makes rear facing led stip signal lights for the Spyder mirrors. I can't find them on their site but if you contact Reggie he will make a set.
    2012 RT Limited (White)
    Tricled fenderz, 3rd and 4th brake lights, mirror mounted rear signals and tip lights. HID head and fog lights. Smooth Spyder. Bajaron Swaybar
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    So who's going to pull the trigger, and then give us a full report?
    Jun 2009
    Snellville, GA USA
    I received them in the mail today & will be putting them on sometime before SpyderFest. Looks like the only tool I'm missing is a guitar pick.
    I'll post something to let you know how it goes...
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    The Best of Luck to you with this project!
