popping back thru air box?
i have had this happen at different conditions . probably only 7or8 times any one else?
kinda sounds like pop back thru air box from carbs(T.B's)for a quick sec
HAPPY TRAILS SPYDEE PE#53
SpyderLovers Founder
Re: popping back thru air box?
Can't say that I have.
No backfire for Silver #1232 in over 1K miles.
Happy owner of Silver PE #1232
All The Gear All The Time - ATGATT
Gulf Coast SpyderRyders
Yes, when I was in Texas in January it felt like a cylinder was misfiring and the oil light came on. I pulled over and checked the oil & it was fine. Started it up and it ran just fine...until last week. It's misfired 7-10 times in 2 weeks. I just pull over, shut it off, wait a couple of seconds and take off. Some times it does it again right away so I repeat the process until it keeps running. It seems like once it runs for 15 minutes or so it doesn't do it any more...any ideas? I'll definately take it in for a check-up but just wondering if others have experienced it.
Also, I'm starting to get a hot spot on the muffler. Is BRP covering that under warranty? I wonder if I could upgrade to the Hindle? What's your experience?
