Originally Posted by NancysToy
No such luck, but there is an unswitched 10 A accessory harness and connector beneath the front trunk on the left side. You may be able to see it tied near the left shock mount on a 2010. Same circuit as the rear trunk outlet.
That may work I will see if I can get it there easier than from the battery. Thanks Scotty
Motorbike Professor
Battery access isn't that tough, just remove the left side mirror, deflector, and body panels.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
USB Charger Version
I installed my marine grade USB dual charging socket in the speaker grill also.
Blue Sea Systems
Dual USB Charger Socket
Input 12V DC
Output: 5V / 2.1A
Here's where I ordered mine from: http://www.sierraexpeditions.com/ind..._detail&p=8670
Kraig
2012 RT SE5
2010 RT-622 trailer
2013 Triump Bonneville T100
1971 Honda CT70
1972 Honda CT70H
Hey, I like that! I may put one of those in the other speaker.
I am not good with messing with wiring---would love to get this doen at Spyderfest
I am lousy when it comes to wiring things up in fear of goofing it up and tripping a computer.
Is anyone aware of someone doing intalls like this, during Spyderfest?
How long of a job is it? (Time wise)
Thanks!
2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
