After installing the Elkas, the Spyder sits higher. The headlights will need to be adjusted lower.
WOW what a beach hope you have better luck on the other side maybe removing the body panel would be easyier to locate the upper mount and some gloves for the bleaders.
Mike
Isn't that the it is supposed to work?
Bob
Wouldn't it have been easier if you took the Frunk off. Had more room to work on the Shocks and you can get to the sway bar while you have it apart. I am going to do the same thing as soon as it warms up. Like you have your opinion on this. I have a spyderpop gaurd on mine. Thinking if I have to take the gaurd off and the two bolts on the bottom, it would be just as easy to take the frunk off...Have a heck of a lot more room.
SpyderLovers Sponsor
Originally Posted by Tin Can
Bob
No.... The shocks would be somewhat more easily accessed but you're going to more than pay for that with the difficulty and time spend removing and replacing the Frunk on an RT.
Thanks guy's for the input....Will take your advice.
For those who are planning on getting them, hold out till Spyderfest and let the pro's install them. I had mine done at Lamonts BBQ last fall and there was no charge for installation.
Indeed. I always bring plenty of Band Aids with me for that event anyways.
"Stealth" Project Elka...
Bob that doesn't sound very encouraging. I just bought some '12 OEMs from flybuddy for my '10 RT-S and now wonder if I should wait for spring and let the dealer swap them.😜NAH! I can do it. Also have the BajaRon bar to do.
Spyder Phyl
Well I'll be a Monkey's Uncle (And apologize to our Simian friends as well ...); the second one slid into place about as easy as I would have hoped.
I even got it in place JUST before the Missus walked in... I didn't even have time to note it in the bike's records yet...
So at least the Elkas are on... The RonBar is next!
Bob, did you also purchase an Elka rear shock? I missed which model shocks you bought. I'd probably get new all around as two up is pretty common for us. Also thinking the sway bar is a good investment. You have a good head for these things and I'd like to know your thinking on why you selected the model Elkas you did. Thanks so much!
Madonna
2018 RT Limited Champagne Dark
Originally Posted by pwilbarger
Bob that doesn't sound very encouraging. I just bought some '12 OEMs from flybuddy for my '10 RT-S and now wonder if I should wait for spring and let the dealer swap them.NAH! I can do it. Also have the BajaRon bar to do.
Spyder Phyl
Don't wait you can do both of these projects easily. Swapping the shocks shouldn't take long at all. Maybe the Elka's make it more difficult or maybe it is just Bob being Bob. We swapped 10 for 11 shocks on mine and it was a piece of cake.
Removing and reinstalling the bump skid takes more time than swapping out the sway bars.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I was never too good at waiting to become "patient"...
It's probably a good thing to break out the wrenches and Band-Aids in an attempt to learn something about what makes these bikes tick!
NICE!!
Spyderfest 2013
Do you know of any specials yet for Spyderfest. I want o get a set of Stage 1 for my 2011 RT.
