Just installed Cruise-mate cruise control on my 2011 Spyder RS. Easy installation ( just make sure you use the jigs for re-drilling and tapping the throttle housing). It is a clean setup with just spring loaded lever that comes from the bottom of the throttle housing for holding the throttle open via friction. Have used on the highway and with my newly installed ICSI hand brake I'm good to go for long highway rides.
I installed a cruise-mate and the hand brake before we went to Colorado last summer...I wouldn't be without either one,now...There are better and more complicated cruise controls out there,but basic is fine for me..I just wanted a "once in a while" hand relaxer...It did the trick!
Lambo
Who makes this cruise? I take it this is a quality product I could install myself? I am two weeks from an open carpal tunnel release surgery and will most likely need the help this year.
Three in the garage, and I think I can fit at least one more in.....and then we will have to build another garage.
The roads in NY are so bad that I am glad we bought a Ryker Rally
Crusie mate sold me the drill bit and tap bit for 10 bucks - was very easy - you need to make sure that the throttle housing is put in vise since the housing plastic grabs the bit when drilling.
One other thing you may want is a throttle assist. It is a paddle you rest the heel of your hand on and relieves pressure on the wrist. It really helps out on long rides.
Gee ... Cruise control on an RS? That sounds like a reason to buy a new 2013 model; it's now standard equipment!
Hey Bob, we cruise on the RS too. It's like the person who sees a house they want but wishes it was in a different neighborhood. That's how it is with some of us RS folks, we like some of the features of the RT, but prefer them on the RS.
standard on the new RS??!!!
I've had cruise-mates on 3 of my previous harley's I was glad to see they made one for the spyder. That is definately a must have mod in my opinion.
MY RIDE - 2011 RSS SE5 Alloy Orange/Matte Black MY MODS - Yoshimura Exhaust, BRP Comfort Seat, Fog Lights, Battery Tender, 4.5" Easy Risers, Kuryaken Iso Grips, Cal Sci XL Windshield, Cruise-mate Throttle Lock, Green Air Filter, O2 modifier, Weaver Floorboards, Baja Ron's Anti-Sway Bar, Smoothspyder Adjustable Backrest, Center LED Tail Light and Magic Brake Flasher.
There is no need to remove the grips - the throttle housing is what you work with and it comes apart with only three screws. The directions are OK ( not great). To remove the throttle housing so that you can put on a vise you also have to remove a switch from the housing which is also only three screws easy to get to. When drilling the housing with the provided bit I added WD40 to the bit end and slowly worked the drilling. Key is make sure you use the jigs provided to keep everything straight.
I now have pretty much all the performance mods on my RS - outside of any Bling I like where my RS is as a bike -
I added Criose~Mate to my and what a blessing it was for me!! I did not have a vise to put the Throttle Body in (sure wished I did) as it turned out I was very careful and did not have any serious problems. Cheap $50.00 and all parts came with it in one package. It took more time to figure out how it all went together than it did to do the actual job of remove ~ drill ~ tap ~ assemble. It is also adjustable tension as parts seat in. it came in very handy from Texas HWY 10 to Calf. to I~5 to Salem. CAUTION ~ DO NOT USE ANY CRUISE CONTROL DEVISE IN WET OR SLIPPERY CONDITIONS be it Bike ~ ~ or Cage !!
My husband installed a Cruise-Mate on my RS, but I am the one having trouble using it. It is either losing or gaining speed. Any idea what I am doing wrong?
Keep in mind there is no electronic feedback to adjust your throttle it is a mechanical mechanism so any change in environment i.e. headwind or highway slope will either increase or slow you down. You can adjust the mate so that they is enough play to change the throttle position even with the mate is in the cruise position.
Ride safe
“The only thing necessary for the triumph of evil is that good men should do nothing.” Edward Burke
Loving my Cruise Mate! I think this is a must have mod. When your right wrist starts to get tired just flip the lever and relax it! Best $50 you can spend in my opinion.
2012 Spyder RS SM5 - Steel Black Metallic"The Murder" Southern Cruisers Riding Club - Chapter 072 - Northern Illinois Two Brothers M2 Pipe; TB Juice Box; Hartco Custom Saddle; Rivco Driver Floorboards; Rivco Heel Toe Shifter; ESI Highway Pegs & Brackets; ESI 4.5" Easy Riser Handlebar Risers; BajaRon Sway Bar; Cycle Sounds Series 3 200 Watt Sound System; 14" Touring Windshield; Custom Dynamics Mirror Extensions; Kuryakyn ISO Grips; Kuryakyn Throttle Boss; Kuryakyn End Weights; Frunk Liner.
