Results 1 to 13 of 13
    Registered Users JaymeG33's Avatar
    Apr 2012
    New Stanton, PA (South Western Pennsylvania)
    Default Painting the vents
    So, one of my winter projects is to paint the vents on my RS. Mine is solid black, I want to paint the vents silver to match the brackets where the foot pegs are located. We have already taken off all of the Can-Am stickers before winter hit. I have seen very few Spyders done like this, not saying they're not out there but I just have only seen about 2-3 pictured. My question is, if anyone has done this, what type of paint would be best recommended that won't flake. I can't seem to locate replacement honeycomb vents for all five that would need replaced. Any help would be greatly appricated. Only 3 months to go until winter is over and I ride again.
    I would guess that powdercoating would be a whole lot more durable...
    Can that be done on plastic?
    arntufun
    Guest
    I used plastic spray paint available at any home improvement store. It's flexable so it will hold up. I also left the front honeycomb black because it would have been to much yellow IMO in that spot. You shouldn't have that issue with yours.
    You can also do the dash bezel as a member showed me how to do it. It really makes it look nice. I also covered the honeycombs on the dash with vinyl to give it a unique look.
    Looks great Randy! Now you just need to get some caliper covers painted to match up!
    Apr 2012
    Quote Originally Posted by arntufun View Post
    Oh ok sounds great and yours does look great also! That's exactly what I mean, just like how you have your vents over the rear tire. I just want a pop of color, so it almost looks like a cushion.
    Dec 2011
    AZ
    Post Spray paint
    For parts like the vents, spray paint in a rattle can will work fine. I've never had much success spraying glossy colors on smooth surfaces - it always comes out looking splotchy compared to paint sprayed with a compressor and gun. But since the vents don't have any smooth, flat surfaces, a rattle can will work fine. Krylon makes a special "just for plastic" paint.
    I would run the parts through the dishwasher first to get them clean.
    Have fun!
    May 2009
    Connecticut
    I used Walmart Krylon "Bonds to Plastic" Silver Hammered Spray paint on the removed vents and the Lower and front plastic and I like it and thats ALL that matters to me!
    Sea Doo GTI-SE 90 Jet Ski!!
    Very Active Member StriperKing's Avatar
    Boonville In
    Quote Originally Posted by cstall View Post
    Have fun!
    I would 2nd the cleaning. If you don`t remove all oil, grease, wax etc. it will not matter what paint you use. Use the for plastic paint and clean very good. I have never tried the dishwasher but sounds good if not to bad or use a good enamel reducer to clean with.
    States We Have Been To On Our Spyder
    My mods: Green filter, Air box mod., Muzzy exhaust, Cat Bypass, Exhaust Heat Wraped, Powder coated all Bare Metal surfaces, Capt. Jim`s Belt Tensioner, Custom Built Highway Pegs, Elka front shocks, RS-S rear shock, 2011 smaller windshield, Dynojet PowercommanderV & Autotune, NGK iridiom DCPR9IEX spark plugs, Maxxis MA-Z4S Victra rear tire, General Altimax HP 185/60R14 front tires, Corbin seat & backrest, BRP hitch. I need to stop!
    Question: Is acetone or MEK too strong to use on plastic?
    We sure don't want a puddle of goo where the parts were!
    Registered Users Campverdefela's Avatar
    Aug 2009
    Camp Verde, Az.
    As mentioned a good cleaning and thorough drying of the parts is a must, using something like purple power follow up with Windex. Acetone might ruin or etch the plastic. Also buy a spray can trigger for a buck at the hardware store to help you get a clean spray pattern and avoid those splatters
    Hindle exhaust, Kewlmetal K&N intake + prefilter, Kuryakyn widow pegs, Kuryakyn grips, Madstad 20in. windshield, Juice Box, 02Modifier, Kewlmetal backrest and carrier, missing air dam, missing belt shield, 1" riser, Kewlmetal handlebar risers,Evoluzione sway bar, Street Magic/Day Runner Pucks, Glo Riders Amsoil, 10w40, Rons performance wires
    Apr 2012
    Quote Originally Posted by Sarge707 View Post
    That vent look is exactly what I am going after. Thanks for the pics! Never saw those ones before!
    Apr 2012
    I photoshopped the vents on my bike a few months back just to get an idea of what it would look like, this is what I hope the final product will look like...
    Can't wait to see the results!
