Results 1 to 15 of 15
    Registered Users Captain Fin's Avatar
    Aug 2012
    Key Largo, Florida
    Default How do guys with big hands check the coolant?
    Now I don't have big powerful hands, just medium size 65 year old weak hands. What a bear to get the cap off to check coolant. Anyone know an easy way to do this!
    Very Active Member btcherm's Avatar
    Howard City, Michigan
    I just call my son.cory.jpgIMG_3121.jpg he just pick up the hole thing.
    I just do a lot of this... and then have the dealer check it for me.
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Rattigan_Roger View Post
    I shine a high powered light on the coolant tank and don't touch the cap.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    washington state
    I hope BRP are watching and taking notes. I'm sure they can make a better way in checking and filling the coolant. I would nice if they(BRP) listen to our needs and take action soon not later.
    2012 Spyder RT SE5 Brake pedal mod
    Aug 2008
    MA & NH
    If they listen I hope they don't forget their sleds. We've had a good time with certain years and models.
    Jul 2011
    PA
    Quote Originally Posted by Captain Fin View Post
    I see you have an RT. No need to take the cap off to check coolant. The tank sits in the body such that about half the tank is visible from below, looking in from behind the front wheel. Half the tank is visible from above when you remove the access panel. Depending on your coolant level, one view or the other will show you the level of coolant. I like to keep mine on the high side so I fill it to the "full" mark on the tank. I find shining a flashlight under the wheel well up through the tank makes it very easy to see the coolant level from up top. If your coolant level is in the bottom half of the tank, shine a flashlight down thru the tank from the top while looking at it from the bottom. Play with it and you'll see what I mean. Very easy. Helps if the garage is dim not full sunlight.
    RT and Gold Wing States & Provinces
    Active Member bertmc's Avatar
    Feb 2012
    Boonville, Missouri
    Lots of good suggestions for observing the level. Thanks. But what to do if you have to add some? When I tried to remove the cap a month ago, I could not get it to budge. Was afraid to put a pipe wrench on it.
    Put something exciting between your legs--ride a Spyder!
    May 2009
    Connecticut
    Same here. I took of 2 panels and looked from behind with a spotlight and it was at the Lower line whick is OK (Cold) so I did not attempt to loosen the cap because I get the opinion you NOT gonna get it back on?????
    I will check during the winter to see if the level goes down at All!
    Sea Doo GTI-SE 90 Jet Ski!!
    Aug 2012
    Key Largo, Florida
    Default Thanks
    Quote Originally Posted by Sarge707 View Post
    I guess it's like checking eggs then. I did get it off and back on, but had a few dings on the top of my right hand from the low clearance of the Tupperware.
    Mar 2008
    Allegan, MI
    Quote Originally Posted by bertmc View Post
    Coolant caps have to be pushed down and turned simultaneously to be removed. Just turning it is not enough, although they will twist back on. Removing the cap with a tool will damage the coolant tank. The best access is gained by removing the adjacent body panel, but the RT is still a tight fit. Find a friend with skinnier hands, or hire a professional contortionist.
    When replacing the cap, be sure to tighten it back to the second detent. If you quit at the first notch, the coolant will overflow.
    -Scotty
    magical member harrypottar's Avatar
    May 2012
    Bellingham MA
    Just have the wife do it, now before any one gets on their high horse about miss treating my wife, I do I least let the bike cool down first. Gee what do you take me for
    harry
    "Draco dormiens nunquam titillandus"
    My Rides;
    Nimbus 2000, Ford Anglia, 2012 Spyder RT Limited, Pre 14 Vintage Classic Collectors Edition!
    Favorite Ride;
    Nimbus 2000 boy this thing can fly.
    Mods:
    Charm of invisibility, Reparo Charm (cuts down on service cost)
    One always wonders about roads not taken.
    Oct 2007
    watsonville CA
    Default coolant tank
    change it to a tank with sight glass, or maybe change it to a 2013 tank on the new spyders.
    washington state
    Quote Originally Posted by ivanlee View Post
    Is the site glass accessible without removing any panel?
    Oct 2007
    watsonville CA
    Smile
    Quote Originally Posted by jerpinoy View Post
    Remove the cover over the rad cap.
