Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 91
  1. #26
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default negative
    i tried a 1/2 nipple and it would not go. the o.d. looked closer to 7/8 than 3/4, so i put on the center clamps and gussets. it feels rock solid. bike wouldn't start , to test out the lift. same as sunday. cleaned and tightened the ground cable. checked voltage with a meter, showed 12.9. put tender back on and bike started mon. morning. went to start it this afternoon to test the lift, and would not start. ur thoughts?
    it was fun while it lasted.
  2. #27
    Apr 2011
    GREENVILLE, SC
    Default GR8
    GR8 JOB COZ.....
    half the fun of owning a SPYD3R, is creating things to do with it and for it....
    Dan P
    Easley, SC
  3. #28
    May 2011
    cincinnati, ohio
    Default thanks dan
    i've got a whole laundry list of things i want to do once i get this lift set up correctly . not to mention this new starting problem.
  4. #29
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by coz View Post
    Check battery voltage. If low, charge the battery then remove the charger. In a few hours to overnight, check the battery voltage. If less than 12.7, the battery is not holding a charge or you have a parasitic loss. If 12.7 or above, it should start the Spyder. If not, and the terminals are clean and tight, check the rear frame grond for tightness (negative jumper terminal under the seat) and check the positive jumper terminal (starter relay) for tightness or a loose post. If all seems well, hold the throttle wide open to prevent starting, and watch the voltage as you crank the starter. It should remain above 10.0 volts. If any of the voltage tests fail, replace the battery.
  5. #30
    May 2011
    cincinnati, ohio
    Default thanks again Scotty
    i'll start running it all down tomorrow. just in time as some serious cold gets here tomorrow .
  6. #31
    Mar 2012
    Beaverton, Oregon
    Here is a pic of my setup.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
  7. #32
    May 2011
    cincinnati, ohio
    Default thats nice
    larry. looks like a good quality lift table too.
  8. #33
    May 2011
    cincinnati, ohio
    Default lift tables and batteries
    lift table mods are all done. original battery has taken a . new motobatt on order, 112.50 delivered.
    will push spyder up on the lift to test it tomorrow. ,,,,,,,,,,
  9. #34
    May 2011
    cincinnati, ohio
    Default it's all good
    everything works as anticipated. if anyone wants to do this to their h.f. lift, use 1 1/2 inch pipe and clamp it down in the center and outer edges. i love the folding ramps, but it was alot of extra work. solid ramps would work just fine. feel free to pm with any questions. i'll post better pics in the daylight.
  10. #35
    May 2011
    cincinnati, ohio
    Default 12 hour test
    spyder was in the air overnight. lift table held perfectly. more pics. I highly recommend a lift table to all spyder owners. it'makes all spyder work as easy as it is hard without one. you don't understand until you see your axles waist high.imagine cleaning your wheels, standing up. i should have got one of these about ten years ago. To summarize, all these lift mods could be easily done over a weekend. all you need tool wise is a circular saw, and a good cordless drill, or an electric drill if thats what you have. expect to pay around a hundred bucks for lumber, pipe and clamps. i've done the hard part ,figuring everything out ( big thanks to dannymax and scotty ).
  11. #36
    May 2011
    cincinnati, ohio
    Default less doctor visits
    for arthritic knees and twisted backs.it will pay for itself in reduced healthcare costs. seriously though, i just polished the whole bike in 90 min. standing up, and it was overdue for a clean up.
  12. #37
    Dec 2011
    Columbia county NY
    Default Ahhhh!
    I love it when a plan comes together!! Nice job Dan'l!!
  13. #38
    Invalid Emails
    Sep 2012
    Clermont Florida
    A great read Dan the lift looks to be a winner hope you get the starting problem worked out
    have a Merry Christmas.
  14. #39
    May 2011
    cincinnati, ohio
    Default thanks
    Quote Originally Posted by mcaccamise View Post
    new battery should be here in a few days, that should take care of it Merry Christmas to you too.
  15. #40
    May 2011
    cincinnati, ohio
    Default space considerations
    if you think you don't have room for a lift table, you probably do. the spyder pretty much covers up the whole thing , except for the long ramps . just park on it , thats what i do. picked up some red paint ( free ) today for all the wooden parts. as soon as mother nature co-operates,,,,,,,,,,,,,,,,,,brrrrrrrr.
  16. #41
    Mar 2012
    Beaverton, Oregon
    I agree! My lift is a Handy Lift but it is where I park my spyder everyday!
  17. #42
    Invalid Emails
    Dec 2011
    Arcadia, FL
    May 2011
    cincinnati, ohio
    Default nice work e z
    what size pipe did you use ? i'm not trying to rain on your parade, but it looks like it is bending in the middle. that's what mine did, so i added the center clamps and wood bracing for more strength. i would hate to see someone or their spyder get hurt doing this mod. rt's are alot heavier than a gs. great job. i should also add that i notched the table edges to accept the pipe. that allows the pipe to be clamped down tightly to the table top.
  19. #44
    Invalid Emails
    Dec 2011
    Arcadia, FL
    Default Reply Regarding The Pipe Diameter
    You are correct, there is a bow in the pipe. I used heavy wall conduit rather than black Iron pipe. I am adding a third peiece of pipe to address the bowing. I did not see it until I looked at the pictures after they were posted on here. Thanks for the heads up.. Have a great day.
  20. #45
    Mar 2012
    Beaverton, Oregon
    For mine I used heavy wall iron pipe. the pipes on mine, however run under the lift top & extension pieces using existing factory pipe holes.
  21. #46
    May 2012
    pell city alabama
    Default THANKS FOR IFO
    Ideas like this lift an ramps are why I love this web site! there are tons of great mods on here an ya'll share them with the rest of us spyder riders. with all the info on here some manufacteres could make alot from ya'll
  22. #47
    May 2011
    cincinnati, ohio
    Default thanks Pete
    it was a fun project, except for it being wintertime. i hope it will help some folks out.
  23. #48
    May 2011
    cincinnati, ohio
    Default all tuned up
    finally got some good weather, did a little painting. anybody else doing this to their lift? or thinking about it ? by the way....... installed new motobatt battery last week, spyder fired right up.
  24. #49
    May 2012
    Greenfield, WI
    SPYD3R - your garage is WAYYY to clean.
  25. #50
    Apr 2011
    GREENVILLE, SC
    Default CLEAN
    Quote Originally Posted by Huntindawg1962 View Post
    CLEAN...?
    i guess that comes from my training... i built jet engines @ GE for a living, and 'CLEAN' was an absolute necessity... we didn't want any FOD getting ingested into an engine , so 'clean' was programmed into our DNA... but THX... nice that you noticed...
