Almost torched the bike! Huge leak in upper right side.
It all started with a coolant leak; a pinprick that shot coolant out onto the front cylinder. Dealership needed to verify to process warranty action. I decided to help by removing all forward tupperware to show them the reservoir leak upon my arrival.
While pulling out of the garage for my hour ride, I noticed a strong fuel order and as I pulled out into the sunshine, a grey cloud rose to my right. I shut the ignition and scrambled off the bike. There is a shiny metal canister next to the right knee that appears to be a fuel filter. Both ends seem to be crimped in the middle. Fuel pours out the middle when the system is pressurized.
If I hadn't had the tupperware removed at the time, who knows what would have happened.
Now I'm waiting to see what the dealership has to say.
I recall seeing an RS last year that had been torched, and it seemed the fire had originated in the same area. Does anyone have any news on this issue? Are there any questions I should be asking that are not readily apparent?
There have been some RS fires reported on here over the last couple years. Not recently, that I can remember though. I do not believe they ever came to an actual conclusion regarding product liability.
Others will have more complete information.
That is, indeed, your fuel filter. Glad you noticed the problem before it toasted your marshmallows. Simple fix, the dealer should be able to handle it, or you can do it yourself if you have the proper crimping pliers for the full-seal Oetiker clamps.
Scotty,
Could you please give us a little back of background on "Proper Crimpling Pliers" and "full-Seal Oetiker Clamps"?
You lost me...
But that ain't a tough chore to accomplish anyway!
Scotty,
You lost me...
The standard hose clamps on most of the Spyder are Oetiker clamps. They are a complete circle, with a raised section that is pinched together to tighten the clamp. They are often used on the production line, because they can be installed by machines, but there are other advantages. There is a wide variety of specific applications, but they come in two basic types. One type is a basic circle, with a raised section to crimp and clamp. That section does not press tightly against the hose. The other type has an additional strap across the clamp area, allowing full contact with the hose. That is a Full-contact Oetiker. The crimping priers are much like tile nippers. They have jaws that are beveled, allowing them to fit in the small recess in the raised section, and apply even pressure across the clamping area, crimping the raised section uniformly and quite tightly if the correct size clamp is used. The clamps come in small increments of sizes, because there is not a large reduction in diameter when they are crimped. Here endeth the lesson...
Just asking but WHY would you stay with this type of clamp instead of changing them out as they fail to worm gear screw type clamps???
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
Drove down to the dealer (they had a fuel filter in stock), and took it home. The Oetiker clamps were a PITA to remove. I replaced the Oetiker's with alligator clamps, and discovered a small leak on the tank-side of the filter. I had to cut off about 1/8" of the hose. Re-installation checks were good.
Question Scotty: Do you think I should have the dealer change the clamps tomorrow again for the Oetiker's?
As far as the coolant leak, I saw the new re-enforced tank tonight and they will install it tomorrow, as I wait.
Kudos to Coleman PowerSports in Woodbridge!!
The alligator (pinch) clamps do pretty well on suction lines, but as you have seen, they don't necessarily like pressurized systems...especially if they are just a smidgen too big for the hose. Worm clamps are safer, but can leak at the rigid mechanism if the clamp isn't closely sized to the hose. Oetiker clamps also need to be very carefully sized, but the BRP fuel filter comes with them. They do need to have the correct type of pliers for tightening them. Trying to substitute diagonal pliers (side-cutters) or something similar does not put even pressure on the crimp, and can lead to huge problems, including clamp failure. That's not so good on a fuel system! If I didn't have access to the correct pliers or some (dull) tile nippers, I'd probably go with some mini worm clamps, or back up the pinch clamps with worm clamps.
Worm clamps, or more commonly refered to as hose clamps, do work well on some hoses. The main issue is they tend to get over tightened forcing the rubber out through the screw holes. They can also be placed too far back on the hose, allowing the hose end to flare out leading to a leak. They will loosen over time from heating and cooling. As with any clamp, proper sizing, placement and torquing is the key to a leak free hose. Best to stay with the OEM, IMHO.
If your going to do fuel system repairs yourself buy the correct Oetiker tool and the clamps. IMHO using worm, hose, pinch clamps of any kind on a fuel injection system is not a good idea. Oetiker clamps are kind of a pain initially, but once you've used them a few times it's really no big deal.
It also gives you a good reason to buy and add a new tool to the toolbox!
I have just discovered a couple of days ago when I got my Spyder out to ryde after it sat in the garage for several weeks there was a wide stain on the concrete. I put cardboard under it and today when I pulled it I could tell some type of fluid leaked onto the cardboard. I put it back under and pulled it about 5-10 minutes later and had kind of a green colored droplets on it. Is this similar to what yours was doing?
I am always worried about the chance of a fire. Every time I pull into my garage and park, there is a strong odor of gas coming from my spyder. I have looked everything over pretty good and can't find the source of the smell. I have seen others comment on the gas smell. Is this just normal for a spyder?
That is coolant. If your cap is tight (turned to the second detent), see your dealer. ...and check the coolant level before you ride!
recommend using worm clamps designed for fuel injection connections, the clamp's strap wraps in the inside allowing for even pressure. major advantage is that you can tighten as the rubber of the hose shrinks with age. i replace all oetikers at the first sign of seapege. easy check: with engine running and systems pressurized, wiggle hoses and check for seapege.
