SpyderLovers Founder
MOgang Member
I appreciate the spot to introduce myself, Lamonster, and the kind words, Yazz.
Delphi Innovations is a relatively new metal fabrication company. Our purpose is to turn your ideas into your ride's latest unique modification. We're a total solution provider; all you need to do is supply us with your idea and we'll take care of the rest, even if it's a drunken drawing on the back of a beer-coaster! We can also modify/plate existing parts!
Contact us at delphi.innovations@gmail.com.
All projects will begin with a computer drawing of the part (e.g., 3-D CAD drawing), modeled after your intents. This modeling eliminates any room for confusion as to what the part will look like in the end.
For fabrication, we're capable of engineering the entire process, start to finish. The following is a list of some capabilities that we're able to bring into your projects. All capabilities are provided by facilities local to us.
- CNC Waterjet cutting
- CNC Laser cutting (for fine details)
- CNC Plasma cutting (for thick cutting)
- Arc Welding
- Precision Machining
- Metal Plating, Electroless (e.g., nickel plating)
- Metal Plating, Electrified (e.g., chromium plating)
- Electropolishing
A typical project progresses as follows:
- You describe the part you want any way you want. We do accept napkin scribblings.
- We send you a 3-D drawing of the part (typically JPEG image), and you critique until you're satisfied.
- We send you a fabrication process (e.g., materials, machining, plating), and you critique until you're satisfied.
- We fabricate the part, and ship straight to your doorstep!
At the moment, we've produced a full set of GS/RS/ST body panel inserts that are entirely clip-on. Worried about the clips falling off? They survived a trip to Alaska and back with no problems!
All sets are made of nickel-plated steel, cut by CNC laser. As a testament to our high quality levels, we went through three separate chromium platers before switching to nickel plating, due to quality assurance issues. Nickel plating also provides much greater durability, and can be laid on thicker.
A do-it-yourself installation manual is available on the website!
- Arc Welding
- Electropolishing
At the moment, we've produced a full set of GS/RS body panel inserts that are entirely clip-on. Worried about the clips falling off? They survived a trip to Alaska and back with no problems!
Nothing for the RT Folks yet.........
Ultimate Spyderlover
2012 Spyder RS S SE5 Magnesium, Power Commander V with Autotune, HMF Exhaust, Green air filter,
TricLed/Custom Dynamics Led Project titled "Knight Rider"
That's the next project. I'm working with a local Spyder dealership to get measurements and dimensions, and to test on. At the moment I was thinking of just doing the two black, pop-out grills that are near your feet. Would any other locations look good, that you would suggest?
That's a real good start!
- it is what it is - 2014 Black RT-S - Baja Ron Anti-Sway bar, lots of LEDs, Spyderpops Skid Plate, Twisted Sister HID Driving Lights, Tricled 2nd, 3rd & 4th brake lights, F4 Customs vented windshield, Lamonster highway pegs, Ultimate Tall Boy seat, Utopia backrest
