Results 1 to 13 of 13
    Registered Users ABQ_Spyderman's Avatar
    Jun 2011
    Albuquerque, NM
    Default Has anyone had to replace their VCM?
    I just got back from the dealer and they're telling me I need to replace my VCM. $2,700 parts & labor. Just wondering if anyone has been down this road. At that price I'll be parking my Spyder until late Spring while I save up. Which is a crying shame considering it's prime riding season in Albuquerque right now.
    Of note: They contacted Can-Am and were told we could try replacing the master cylinder first. That could potentially fix it. But that's $800 and my shop is telling me they really don't think that will do anything and it's just going to blow $800 before I spend $2,700 on the VCM replacement.
    Any words of advice out there?
    Thanks as always.
    --Andy
    2009 RS SM5. Passenger Backrest,
    Sport Rack, GloRyders, TricLED Dayrunners,
    LED Halo Kit, and LED fender tips.
    Oct 2011
    Kalamazoo, Mi
    Well I would be googling the heck out of salvage sites looking for a used one. There was just a post on the forum within the last 48 hours of a Spyder that looks like it might be totaled. Check with the major insurance co's about the possibility of salvage parts. JMO
    2018 F3-T
    2018 F3-T , Pearl White
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Lightbulb
    According to the service manual - A VCM failure is "not likely to occur". There are loads of things the service manual suggests checking before making a final determination it is bad. Wish I could cut and paste it all, but can't. Perhaps someone else can. I'm in no way saying it was not properly diagnosed by your dealer. But? That's a lot of dough. Good luck.
    Very Active Member kinggeek's Avatar
    Jun 2011
    Cincinnati, OH
    Quote Originally Posted by Jerbear View Post
    From the manual:
    VCM Troubleshooting
    A VCM failure is not likely to occur. These modules have proven to be very reliable. Prior to replacing a suspected VCM, take the following into account.
    The problem can be related to a hydraulic function, check the following:
    - Brake fluid level
    - Brake line leaking, bent or pinched
    - Brake caliper
    - Master cyl inder (including piston rod position).
    The problem can be re lated to an electric function, check the following:
    - Fault codes
    - VCM electrical connector. Refer to WIRING HARNESS AND CONNECTORS subsection for detailed information on the VCM connector
    - Wiring harness condition.
    NOTE: If pins or terminals are not clean, check VCM ha rness connector seal condit io n and ensure connector mechanism properly locks connector seal against VCM.
    Try disconnecting and reconnecting the VCM connector to see if it "cures" the problem.
    As a final test. try a new VCM without disconnecting brake lines from the old VCM. Proceed as follows:
    IMPORTANT: Disconnecting brake lines would require the system bleeding.
    1. Connect VCM connector to a new VCM.
    2. Turn ignition switch ON. NOTE: It is normal that some fault codes appear at this time.
    3. If problem persists. the trouble is elsewhere.
    4. If problem is now solved, the VCM in the vehicle is faulty. Install the new VCM in the vehicle.
    Hope it works out not to be the VCM. Hope this helps.
    Kinggeek
    Mandeville,LA
    VERY HAPPY Spyder Ryder!
    Where have we been on the Spyder? See below:
    Can-Am Spyder ST-S SE5 in Congac
    Apr 2012
    Exclamation
    Warning Always disconnect the battery prior to disconnecting VCM connector.
    Just in case you decide to check anything yourself.
    Jun 2011
    Albuquerque, NM
    Just wanted to say thanks for the responses. I'll run these by my service guy and see what he has to say.
    Thanks again!
    --Andy
    Very Active Member captblack's Avatar
    Oct 2011
    Woodbine, GA
    Are you trying to convince Becky that the $2700 would make a better down payment on a new ST?
    Bill
    Pride Runs Deep Semper Tacitus
    An armed man is a Citizen; an unarmed man is a subject....
    2017 F3 T SE6
    2015 Vulcan Vaquero ABS
    ALR Chapter 401 (Hilliard FL)
    GA & FL Patriot Guard
    Jun 2011
    Albuquerque, NM
    Quote Originally Posted by captblack View Post
    That would be nice! Lol
    However--I have to pay off my RS first!!
    Jul 2011
    Mitchell, Ontario, Canada
    Jun 2011
    Albuquerque, NM
    Brother I wish! I need the VCM not the ABS. But thank you man! Good lookin out!!
    Invalid Emails
    Dec 2007
    winnipeg mb
    Quote Originally Posted by ABQ_Spyderman View Post
    The VCM and ABS pump are one and the same:
    Active Member iridenow's Avatar
    Sep 2019
    Phoenix, AZ
    Thanks as always.
    --Andy
    Assuming it did go bad, would it not be covered by warranty or extended warranty?
    Fred is a 2010 RT SM5 - Sold.
    I am not a mechanic. When I have a tool in my hand, 911 needs to be on Standby.
    This thread/discussion was waaaay back in 2012, and ABQ spiderman hasn't been on the boards here since mid 2014.... not sure you'll hear from him now.... Others might know about the warranty/ext warranty thing for newer Spyders, but I'm pretty sure his RS is well out of ANY warranty by now!
