Results 1 to 6 of 6
    Registered Users smporter420's Avatar
    Dec 2011
    Eagle Grove, Iowa
    Default Amber 20 LED 7W BulbS/7507BAU15s
    http://www.v-leds.com/Exterior-LED/T...-p7678744.html
    Will these bulbs just plug into either the front or rear stock turn lights without any other modifications ? A guy on here said somthing about flipping the wires on one side to make them work. He installed these as front turn lights, can they be used for rear singnals as well? You would think you'd be able to just plug em in and thats it. The wattage have any play?
    Registered Users pro10is's Avatar
    May 2011
    USA
    You have the correct base, and I assume you checked the specs to ensure they are not too wide or long for the housing. However most led bubs must have the correct polarity. If you have a voltmeter check to be certain the center contact of the bulb housing is positive. If not you have to swap the wires. You can do this by carefully cutting and resoldering them, or you can carefully push the pins out of the connector and swap them.
    If you use led bulbs to replace any light that blinks, you will probably need a load resistor. You need to fool the blinking circuitry to sense that it still has an incandescent bulb. If you don't, the led bulb will blink way too fast.
    I see that the bulb you're looking at is out of stock. Here is another bulb that will work and is considerably less expensive:
    http://www.superbrightleds.com/morei...d-product/527/
    For plug and play led options you can also check out the site sponsors ESI and Custom Dynamics on the front page of this forum. The Double Play and Triple Play products are excellent.
    Default THE BULB LISTED HERE
    Quote Originally Posted by pro10is View Post
    So Jim, the above bulb is a direct swap for the turn signal bulb in the GS/RS , without switching the wires and/or adding a resistor.??? Is this the one you have in your turn signal.??????......Mike.......Thanks
    May 2011
    USA
    Mike the bulb I listed is a direct replacement for the front blinker lights. A load resistor is required or else the lights will blink too rapidly.
    Default LIGHTS
    Thanks Jim.......and for the PM also.......Mike
    Very Active Member sabunim5's Avatar
    Jan 2008
    Pensacola Beach, FL
    Is the rapid blinking really a problem as long as the Nanny is happy. Sometimes a quicker signal flash will get a cagers attention better because we react more to things that aren't the norm. Just MHO.
    Happy owner of Silver PE #1232
    All The Gear All The Time - ATGATT
    Gulf Coast SpyderRyders
