New RT floorboards.
Does anyone know if the new 2013 RT floorboards will fit on older RTs, and if we'll be able to buy them if they do?
Phil
I may be old, but I got to see all the cool bands.
2011 Spyder RT-AC
you mean the 2013 RT floorboards (I assume)
Phil
2011 Spyder RT-AC
They are listed as an accessory on the Can-am Spyder website ($999.99) but don't know if it will work on the older models. Just have to wait and see when the catalog comes out.
2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
also the people at CFPS are looking into this also and will send out an email to us on record with them when they get the answer
2014 RT S SE-6 Cognac, 2014 Indian Chieftain. Retired Navy Chief
They DO look nice... But for $1000; I'm pretty darn happy with my ISCIs...
SpyderLovers Founder
Yes they will work with all year SE models, not SM.
One of the reasons they are so pricey is because they have a safety feature that no other board has. If for some reason you do not achieve full brake pressure at a stop and the peddle needs to travel below the floor boards to stop the board will release in the front and will allow the brake peddle to be pushed below where the board was fixed. A simple push on the back of the board will lock the board back in place.
Do they install with no drilling required??
Nice! That's one reason I'm still debating floorboards or highway pegs...I'd hate to need more brake than I can get with a floorboard installed
Yes, these are a bolt up mod.
Everything sounds good but the $$$$$$$$$$$ price
floor brd for sale
RT-S PE#0391
Decent Picture?
I have an RT-S SE5 and given Lamonts comment, would like to evaluate the 2013 floorboards. I currently have Inspector Gadget's version which have been great, but might like to look at something a bit more substantial. ISCI or the Can Am 2013s for the RT SE5 would be the ticket.
Can anyone answer with a link/URL that actually shows a clear shot of the 2013 RT SE5 floor boards?
Thanks
~ Surfer
SpyderPop's with the new higher brake riser...
Regards-
Frank.
2014 Cognac RT-S SE6 1330
2011 Viper Red RT-S SE5 998 (sold)
MY FLOOR BOARDS
My floor boards have no such issues...
you have plenty of room above the board for the brake to function properly...
and my floor boards allow you to keep the existing 'pegs' so that you have two positions for your feet...
on long easy rides, my feet are on the boards... in the 'twistees' or in traffic i'm on the pegs....
i'm current building a 'plug' so i can build a 'tool' so i can start producing these in numbers... they will be fiber-glass and will anchor to the chassic... i'm 256 lbs, and i can stand on these without any problems... my current 'boards' have a 3/4" box-steel-chassic, so i'll need to TEST the fiber-glass prior to making any statements about their capacity... BIG BIRD & i have had these on now for almost 2 years, and both being old timers, with bad hips, they are a great piece of equipment to have...
Spyd3r's Floor Boards
I''ve had them for a couple of years like Dan says. There was an issue that came up while Carmen and I were on the 10 month RV trip around the country and I can't tell you how much I missed them... as soon as I could Dan and I put them back on... they work even in the traffic and in town. Now if I could just get my throttle wrist to quit hurting...lol
Ride in comfrot,
John
Seal FloorBoards
Isn't this is aan RS not an RT?
Originally Posted by FrankPa
are incredibly nice...
The 3/4" brake shim has completely solved any "bottoming-out" braking problem.
Ride in comfort,
John
Seal Floorboards
2013 Floorboards
Lamont, do you see any conflict with the floorboard and the NBVs?
Kevin
2012 RT Limited (pearl white) + bling
Shouldn't be a problem. Not sure if these are going to work on a 2013 till I get one in my hand but I'll make adjustments if needed.
Sounds like a good safety feature but IMO if they are so concerned with safety they
should add the right hand brake like all other bikes have.
In a panic situation I can usually get on the hand brake before finding the foot brake.
-Jimmy
2019 Ryker 900
2018 Honda Goldwing
Banged Up Member
Thanks
~ Surfer
Hopefully you can see it in the below.
https://sphotos-b.xx.fbcdn.net/hphotos-prn1/72066_3832105168878_2004699480_n.jpg
Banged Up Member
Let me try it another way: just click on thumbnail.
