Results 1 to 10 of 10
    Active Member SteveandBelinda's Avatar
    Canton, MI
    Default Spyder Repair Dealers in Mesa Arizona
    I have a coolant leak that was looked at in Michigan
    before Christmas. I am now in Mesa Arizona till end of February. It is still leaving leak on ground, and need a reputable cost effective dealer to check it out. I have appointment with Nash's Powersports in Mesa, but they charge 120. for diagnostics, and that is not subtracted from repairs, if they do the work, and 120 per our labor.
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Bossier LoUiSiAna
    Extended warranty? I hope , & with the panels underneath they can divert from the actual area of the leak. And are you positive you didn't maybe over fill for the new location, change in temps & altitude, it may have burped somewhat good luck either way keep the orange screens away & carry additional fluids
    Active Member vindex1963's Avatar
    Jul 2018
    Payson AZ
    I can only think of the Ride Now stores.
    2012 RT A&C SE5
    2015 Victory Cross Country (Dyno tuned 118hp 116tq)
    2006 Triumph Rocket Dyno tuned 140hp 154tq)
    Active Member Spydermike's Avatar
    Mar 2018
    Maricopa, AZ
    Sierra Cycles in Sierra Vista. It's a little bit of a ride but they have a very good reputation, and they went the extra mile for me. Highly recommended.
    Mike
    2016 RTL "Boris"
    Foam Grips
    Utopia Backrest
    BRP Passenger armrests
    Bajaron sway bar
    LED Bumpskid w/remote
    Belt guard
    BRT rear lighting w/strobe
    High mount BRT w/strobe
    Dual a-arm LEDs w/turn signals
    Multicolor underground Halo lighting
    LED headlights and foglights
    FOBO TPMS
    Techgripper phone holder
    Lidlox
    Dual USB with voltmeter
    Dakota Digital Compass/Clock/Altimeter/Temperature Gauge
    Vredestein Quatrac 5 175/55R15 - Fronts
    General Altimax RT43 215/60R15 - Rear
    Active Member Spyder Insyder's Avatar
    Sep 2018
    Payson, Arizona
    Quote Originally Posted by SteveandBelinda View Post
    Nash Powersports Mesa, Az. (480)325-1818
    Canton, MI
    Yes, not overfilled. Dripping from lower hose that connect to the tee fitting for radiators. Only dripping when the temp drops in the night. Find has leaked overnight
    May 2018
    Chateauguay, Qc, Canada
    Which of the Spyders?
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Dec 2015
    Oakley Utah
    Quote Originally Posted by vindex1963 View Post
    Those don't have the best reputation for working on Spyders.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Sierra Cycles. Way more competent and affordable. Worth the drive out to Sierra Vista.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Are you still in Mesa, AZ? You had said you were there only through the end of February. So, what did you end up doing?
    2014 RTL Platinum
