Results 1 to 13 of 13
    Active Member CWilber's Avatar
    Matthews, NC
    Default Hot leg, not hot foot
    I have read several posts about hot feet but that wasn't my problem on my RSS SE. I would end up with burnt shins that would remain red for 2-3 days if I rode more than 30 minutes. Didn't really want to get into wraps so solved it by buying soccer shin guards that I wear under my jeans. No more burns! This way, during the winter, I can enjoy the warmth.
    Aug 2007
    Boerne, TX
    Thanks for a great idea. My right leg gets a lot of heat even though I have the "heat shield" installed. I will get a pair of these shin guards this week. Good post for all of us.
    I traded my 2014 RT for a 2017 Mr. White RT-S. I am George Lewis. I live two miles from Boerne, TX. I am 89, retired USAF and Sony Corp. I also have a GW MotorTrike. My email: scoot62@aol.com
    SAVE THE CHUPACABRA
    If you have not been to Luckenbach, your journey is not complete.
    Matthews, NC
    Dick's Sporting Goods sells them singly so if only your right leg gets hot, you don't have to buy two.
    Registered Users lookerjdc's Avatar
    Aug 2012
    Melbourne, Florida
    has anyone tried installing the material thats used for wrapping exhaust pipes? using velcro or something to attach it to the inside of the right side tupperware...
    just curious...
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Quote Originally Posted by CWilber View Post
    UNREAL!
    Apr 2012
    Quote Originally Posted by lookerjdc View Post
    just curious...
    It's the heat that comes from the radiator vents on the right side.
    Very Active Member MidLifeCrisis's Avatar
    Apr 2012
    Gilbert, Arizona
    just curious...
    It would fall off instantly. The tupperwear already has heat sheilding under it, but the edges eventually get hot and transfer the heat to the rest of the surface. That said, it's really not much of an issue, unless you plan to give the spYder a good hug and burn your cheek.
    On the other hand, the right hand vents can be real cookers. Can easily fry up some bacon and eggs, between stops!
    ...in the pink (Girls On Spyders) flamingobabe's Avatar
    May 2010
    Friendswood, Texas
    wrapping your exhaust will help...look into Spyderpops (sponsor here) heat shield...and other products
    #IamARyder #RideASpyder #CanAmSpyder
    MOgang Member Yazz's Avatar
    Nov 2009
    Cypress, Texas
    If your shins are getting cooked, check your 'Y' gaskets.
    Joy
    Very Happy Ryder...
    '09 Phantom and a '15 F3-S
    If you don't slow down, they can't catch you..
    ​If you don't give up, they can't win.
    What a long strange journey its been.
    Active Member bobnaquin's Avatar
    Nov 2011
    St George UTah
    [QUOTE=CWilber;512306]I have read several posts about hot feet but that wasn't my problem on my RSS SE. I would end up with burnt shins that would remain red for 2-3 days if I rode more than 30 minutes. Didn't really want to get into wraps so solved it by buying soccer shin guards that I wear under my jeans. No more burns! This way, during the winter, I can enjoy the warmth.[/QUOTE
    If your shins are getting that hot there is something wrond with your Spyder or your riding gear. I would guess exhaust header gasket but that is q guess. Pull off the bottom plates for the summer time at least.
    Invalid Emails
    Apr 2009
    clearwater
    Default wrapping exhaust
    Quote Originally Posted by flamingobabe View Post
    i wrapped mine from dealer in 07 2008 rs have overheating problem ,limp mode if i site in traffic 10 minutes ,yes had all replaced cap fluid ect nothing works. ? is it the wrapping ,i did it because in wheelchair .
    Matthews, NC
    Thanks Yazz and bobnaquien! It was two leaking gaskets. I'm all fixed now and can ride without soccer shin guards.
    Appreciate your help.
    Nov 2009
    Cypress, Texas
    Glad it worked out.
    Joy
    Very Happy Ryder...
