Hot leg, not hot foot
I have read several posts about hot feet but that wasn't my problem on my RSS SE. I would end up with burnt shins that would remain red for 2-3 days if I rode more than 30 minutes. Didn't really want to get into wraps so solved it by buying soccer shin guards that I wear under my jeans. No more burns! This way, during the winter, I can enjoy the warmth.
Dick's Sporting Goods sells them singly so if only your right leg gets hot, you don't have to buy two.
has anyone tried installing the material thats used for wrapping exhaust pipes? using velcro or something to attach it to the inside of the right side tupperware...
just curious...
Thinks out loud
UNREAL!
Thinks out loud
just curious...
It's the heat that comes from the radiator vents on the right side.
just curious...
It would fall off instantly. The tupperwear already has heat sheilding under it, but the edges eventually get hot and transfer the heat to the rest of the surface. That said, it's really not much of an issue, unless you plan to give the spYder a good hug and burn your cheek.
On the other hand, the right hand vents can be real cookers. Can easily fry up some bacon and eggs, between stops!
...in the pink (Girls On Spyders)
wrapping your exhaust will help...look into Spyderpops (sponsor here) heat shield...and other products
#IamARyder #RideASpyder #CanAmSpyder
MOgang Member
If your shins are getting cooked, check your 'Y' gaskets.
Reason: spelling
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
[QUOTE=CWilber;512306]I have read several posts about hot feet but that wasn't my problem on my RSS SE. I would end up with burnt shins that would remain red for 2-3 days if I rode more than 30 minutes. Didn't really want to get into wraps so solved it by buying soccer shin guards that I wear under my jeans. No more burns! This way, during the winter, I can enjoy the warmth.[/QUOTE
If your shins are getting that hot there is something wrond with your Spyder or your riding gear. I would guess exhaust header gasket but that is q guess. Pull off the bottom plates for the summer time at least.
wrapping exhaust
i wrapped mine from dealer in 07 2008 rs have overheating problem ,limp mode if i site in traffic 10 minutes ,yes had all replaced cap fluid ect nothing works. ? is it the wrapping ,i did it because in wheelchair .
Thanks Yazz and bobnaquien! It was two leaking gaskets. I'm all fixed now and can ride without soccer shin guards.
Appreciate your help.
MOgang Member
Glad it worked out.
Joy
