SpyderLovers Founder
new panel...
Lamont, when you get time, post pics of the new panel. Also explain exactly what changes were made that makes it easier to remove.
Thanks,
Dave
Never leave well enough alone! (Raymond Loewy)
Thanks,
Click on the picture.
My dealer handed me my update panel with no cost to me. I had to give them my letter from BRP. I do my own oil change on the RTS. Bob
I was lucky enough to get one also and installed it. Fairly easy overall and look forward to my next oil change.
I have not received my letter from BRP for the new panel. Are they still rolling them out or is mine MIA?
Originally Posted by rcturner
I have the new panel on my RT and see no way that this helps anything unless you put the hole in the support as suggested in a previous post. The filter screw that is behind the support is almost totally inaccessible. Tightening that same bolt to the proper torque is impossible. Other than that, it is a great improvement.
It helps because you don't have to take off any of the painted panels.
I did drill the support and that is approved by BRP now.
You need to check and make sure your dealer turned in your purchase info to BRP. I've heard that some are not in the BRP system...Go figure
Originally Posted by jmstiffany
I am still buying oil from the dealer. Is there better oil out there I should be using? Less or more expensive?
Check your other post.
I dont understand why but if you live in California you won't be getting one.
Thinks out loud
We did not get a letter because per CA. law BRP could not include us in the new maintenance schedule. But, that does not mean you can not get the new panel. Check with your dealer and see how he is handling it. Probably pay to play since we don't have a letter to give him for reimbursement.
Does anyone with SpyderPops Cat Shields know if they will still fit with the new panels?
MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
10 minute oil change
Does BRP furnish the new panels?
I thought you just went in thru the bottom lamont. they you didnt need to remove any of the painted panels.
jack up the Spyder and access from the bottom (after you remove the splash panel)
2013 Yellow ST-S SM5, Elka Stage1 Rear Shock, 2Brothers Exhaust, K&N Air Filter(soon), TricLED fnt fender LEDs, frnt LED daylight strips, 3rd Rear brake LED, ISCI Hand Brake, BajaRon Sway Bar&Links, Bullant Laser Aligned, Lamont's CAT ByPass, CALSCI Windshield, Works Performance Stage 5 Front Shocks
Previous = 2010 Blue RT-S Spyder SM5
10 minute oil removal with new panel for the RT
Not that easy on the SE, I've tried.
Yes, I installed new panel myself and have the cat shields on there..No problem....Plus with the cat shields I feel comfortable when I'm riding and there are stray cats on the road
You ryders in California might have to figure out an address in a nearby State to get the letter and the parts???
Thinks out loud
Thinks out loud
Originally Posted by Rattigan_Roger
I haven't been paying too attention to this matter but I seem to recall a couple of posts stating that for some reason the new oil change/filters/etc hasn't been approved for CA as yet.
No clue as to why.
Got the new filter and housing. Just no letter for a free or low cost panel set?
I had to pay for my panel since I do my own oil changes. According to BRP this at the perogative of the dealership as charge or not since they get the panel for no charge with the ticket I could have supplied. Shame, I like my dealer but this type of thing costs them more than they know. The panel costs a little over $30 with the 10% discount I get for buying the bike there.
Regards,
Randy
Well, I guess I am one of the few. I take over 3 hours to do the oil change. I kinda talk to the Spyder, look for things that seem unusual, let the oil drain thoroughly, etc. When the new oil is all in the Spyder, I Simple Green the engine and hose off. The engine looks almost as clean as when it was new. Taking time to observe gives me the time to notice if some things may be a little unusual from the last oil change.
And, I do not want the new panel!
Happy Trails!
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
