Results 1 to 10 of 10
Thread: OIL PLUG
    Feb 2012
    frisco city al
    Default OIL PLUG
    OEM oil plug metal is to soft. Any body found a better replacement.
    Active Member Crisis's Avatar
    Aug 2010
    New York
    Aug 2010
    New York
    Registered Users JJW SpyderRider's Avatar
    Jun 2010
    Rockton, IL
    Here are the two sizes needed:
    Engine Drain plug 12mm x 1.5, Reservoir 14mm x 1.5
    RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
    Member of the WSR (Woodstock Spyder Riders)
    Mar 2008
    Allegan, MI
    Three Spyders over a five year period for a total of around 35,000 miles and I have never damaged an oil plug. The secret is in using the proper tools, and using them carefully. Use a hex bit socket on a 3/8" ratchet. Remember that most Spyder oil plugs are hex, not torx. Push the socket firmly into the cleaned drain plug, and hold it there firmly with one hand while you work the ratchet with the other. Be sure and use a torque wrench to snug the plug back down, to avoid overtorqueing and difficulty removing it next time. Replace the copper crush washers periodically, they work harden with age. Even a hex plug can be damaged by poor or improper tools or the wrong technique.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Spyderless Member
    Dec 2008
    north/central n.j.
    The right tool for the job!
    Feb 2012
    frisco city al
    Default oil plug
    Quote Originally Posted by boborgera View Post
    I've been a heavy equip mech for 30+ years I have and use the proper tools The first one striped on the 600 mile service second on 7300 mile service plugs are to soft or folks would not be looking for a replacement. Thanks for the help Neel 1 st service 590miles 2nd @3500.3rd @4400 when del. replaced clutch 4th@ 4500 miles when 2nd del. replaced clutch that first one assembled wrong .5th @7305
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    Scotty's exactly right, but I'm one of those that used the proper tool, but not the proper technique & screwed up the engine oil plug. Ended up buying replacements that have hex heads and let my dealer figure out how to remove the plug I screwed up and had them install the newer and improved plugs.
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
    Springfield, MO
    I have a little trick that works for me. When I'm sure the socket is set in as deep as it can go I use a long handle ratchet and I give it a jerk first instead of just applying even pressure. The quick snap seems to work good for breaking it loose.
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Lamonster View Post
    Good advice! I do something similar, I rap the ratchet handle with the palm of my hand to break the gasket loose. With a copper crush washer, and/or a steel fastener in an alloy case, it takes more torque to loosen the fastener than to install it. "Popping" it loose helps overcome that initial force
    -Scotty
