Results 1 to 21 of 21
    Very Active Member SpyderGirl's Avatar
    Feb 2008
    South Jordan, UT (Salt Lake)
    Default Flaming Spyder!!
    So I was riding home from Spyders in the Redwoods, it was about 95 degrees out, and we were on Highway 1 between Leggett (101) and the coast (near Ft Bragg). I was forced to pull over when the Spyder decided to overheat. I got a high-temp code, the gauge was full on hot, and it was in limp home mode.
    Once I was able to find a spot to pull off safely, I shut it down to let it cool and Geoff pulled up on the RT behind me. A few moments later when I wasn't looking Geoff said "your Spyder is on fire"
    I turned around and saw this and just had to take a picture.
    We are a happy THREE Spyder family!
    My Rides: 2008 Quantum Blue Premier Edition Spyder GS SM5 (#1344)
    2015 Pearl White / Red Can-Am Spyder F3-S SM6
    2016 Intense Pearl Red Can-Am Spyder F3-T SE6
    2019 Chevrolet Volt (ER-EV)
    2003 Jeep Wrangler Sport X 4.0L I-6
    RETIRED Owner / Event Coordinator - Annual Western Regional Can-Am Spyder Rallies
    Spyders in the Redwoods and Red Rock Spyder Rally of Southern Utah
    The West Coast's Can-Am Spyder Community Ambassador
    2008 GS , ISCI Quantum Blue
    magical member harrypottar's Avatar
    May 2012
    Bellingham MA
    what happened?
    "Draco dormiens nunquam titillandus"
    My Rides;
    Nimbus 2000, Ford Anglia, 2012 Spyder RT Limited, Pre 14 Vintage Classic Collectors Edition!
    Favorite Ride;
    Nimbus 2000 boy this thing can fly.
    Mods:
    Charm of invisibility, Reparo Charm (cuts down on service cost)
    One always wonders about roads not taken.
    Feb 2008
    Quote Originally Posted by harrypottar View Post
    what happened?
    My best guess was fuel blow-by into the exhaust system. It was backfiring and must have ignited.
    As far as the over-heating issue, I don't know. I checked the coolant and it was low, but no sign of a leak. I am hoping I didn't damage the head gasket. I will know when I do my oil change.
    I had some bottled water, I topped off the coolant tank and was able to get her home. It helped that it was 30 degrees cooler on the coast.
    Very Active Member MMcc's Avatar
    Aug 2010
    Annandale, MN
    Default Fire
    I had a similar fire in my 2008 GS. One plug wire failed just above the plug boot. Started to lose power, temp started to rise then a backfire and limp mode. Pulled to the side of the road and when I shut it down I watched as fire shot out of the muffler. Burned for about 30 seconds and then went out. I did not have any extinguisher so just stood back. After letting it cool I started it up and running on one cylinder. Limped the final few miles home. Check the plug wires.
    Mar 2008
    Allegan, MI
    Quote Originally Posted by MMcc View Post
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Feb 2008
    Plug wires are brand new. I bought them from Ron a few months ago.
    Mar 2008
    Allegan, MI
    Quote Originally Posted by SpyderGirl View Post
    I'd check them and the plugs anyway, but it may be a difficulty with the coil or ECM in that case. ...possibly heat-related? Ignition woes are almost always the root cause of unburned fuel in the exhaust on fuel injected vehicles.
    -Scotty
    Feb 2008
    Quote Originally Posted by NancysToy View Post
    I will check them and the coil. I was thinking that I need a EFI controller for my HMF pipe.
    Mar 2008
    Allegan, MI
    I's possible, but not common. If the fuel mixure is so lean that it won't fire in the cylinder, fuel can collect in the pipes. I'd look for other causes first, unless a change in weather brings a dramatic improvement. Just remember, new wires can be bad (not likely), vibrated loose, or arcing to the head or engine. Normally, reading the plugs is the first step in troubleshooting, but it is a royal pain on a Spyder. You are good at this stuff, I'm sure you'll find the culprit(s) in short order.
    -Scotty
    ...in the pink (Girls On Spyders) flamingobabe's Avatar
    May 2010
    Friendswood, Texas
    Bad deal...fire and Spyder should not be used in same sentence....hope you find the problem....
    #IamARyder #RideASpyder #CanAmSpyder
    Glad you made it home safely. Keep us posted as you get it figured out and repaired.
    Feb 2008
    I'm sure I'll track it down. I'll report back once I am able to investigate further.
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Sorry about your problem.. but glad it didn't totally go up in flames!
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Feb 2008
    Quote Originally Posted by Firefly View Post
    For real!!!
    I suppose that if you take the viewpoint that, "it could have been a heckuva lot worse!"; then it makes it easier to sit down and figure out what caused this informal marshmallow roast to occur...
    Good luck, and we're all hoping that it's nothing serious and can be fixed easily!
    Does ATGATT include fireproof britches?
    Feb 2008
    It should on the RS with all the heat on the right side. I told our local BRP rep that they need to make pants with a built in heat shield on the right pant leg.
    Sorry... I've got to say it...
    Perhaps a fireproof bikini???
    I feel so ashamed...
    Feb 2009
    Ceresco, Michigan
    Hey now... I've seen Geoff in a bikini..... and it was NOT a pretty sight!
    Feb 2008
    Hmmm, that's interesting.
    May 2010
    Knob Noster, MO.
    I have seen Geoff fully dressed, and that is not a pretty sight
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Feb 2008
    Quote Originally Posted by Blue Star View Post
    Geoff is sitting here wondering how he got dragged (in drag) into this.
