I've been using premium, but have discovered there are some stations in the area that sell ethanol-free gas, but only in 87 octane. I'm going to give it a try, since I assume no ethanol is better than a higher octane with ethanol. Does anyone have any data on that assumption?
Reason: fix fat fingered typos!
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
Originally Posted by Firefly
Only the RT requires higher octane. The RS models are fine with the 87.. last time I checked.
I go with what BRP says. Ran 87 on my GS/RS for 56,000 miles. Tried a few tanks of 91-93 and it was a waste of money.
My 2012 RT says 91 --- so that's what I run.
couldn't agree more. our 2012 rss runs great on 87 and the few times i've tried the 91 and 89 i didn't see any difference, mileage or performance wise!
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
With the difference in price being maybe a quarter per gallon; Assume a four gallon refueling and I'm sorry to have to ask if that dollar all that important?
Put it another way...
Assume that you ride 10,000 miles per year
You get 30 mpg
Total gallons used: just a bit over 333 gallons
Assume again 25 cents per gallon price differential...
That's $83.33 over the course of an entire year...
Motorbike Professor
You get 30 mpg
Amen!
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Good math...Amen +1
When gas was 50 cents a gallon, it was about a dime more to get premium, a 20% difference.
Now it's like 6 or 7%. Not worth considering on a 20K (+) machine.
Some body read his post!
Originally Posted by donnellpj
Is it a full moon yet? Strange things are happening around here lately! 😂
Half a LOF
you do that for two years and you can a free LOF service!
My question has nothing to do with the cost of gas, but is in regard to the ethanol in the gas. The owner's manual for my 2013 RT has bold print where it discusses using gas with a maximum of 10% ethanol . . . the minimum requirement for gas is 87 octane, so it is acceptable, but better performance is derived from higher octane. Bold print items in my USAF maintenance days meant it was very important . . . so, again, I ask . . . does anyone have any information regarding ethanol, and if it is better to use ethanol-free 87 octane, than a higher octane that contains 10% ethanol? Surely, someone knows!
Originally Posted by boborgera
Porsch''a'' Is the Feminine Pronunciation.
I thought Poscha (Portia) was Ellen DeGenerates wife.
USAF '69-'89 E7
Thailand/Vietnam 1972
P/C; Life Partner; [till the next one comes along]
interesting thread...last year, I went to the Adorondaks and rode with other Spyders who got gas less frequently than me......they used premium and I used regular(87 octane)....I have since switched and noticed that I used to get 25 mpg, now I get 30+mpg, even when I two up! so I am sticking with the premium.
We run......
We run 87 with no problems- but hate ETHANOL-----try to put REAL gas in when I can but it comes at a premium in price (Darn it)
2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
Ethanol receives more "bashing" than it truly deserves. Most comments I see about fuel are based on folklore and misinformation -- rather than fact. (The internet is not necessarily a good source for information on fuel. It is littered with misinformation.)
I would say there are definitely concerns about ethanol, (moisture, corrosive qualities, and etc); however it you ride and re-fuel often, some of these problems (moisture) may not be a problem; at least not to the degree you will notice on your Spyder (boats and sports craft are a different deal... do not use ethanol).
However, do not store your Spyder for longer periods with ethanol fuel in it -- at least not without treating the fuel first (moisture build-up mostly).
With regard to mileage, knocking, and power... try it for yourself and see. Make sure you run several tanks of each to compare (there is a difference between fuels).
Temps, humidity, altitude, terrain, vehicle weight (with rider and luggage), driving-technique, and more all contribute to an individual's experience with fuels. Thus, it is difficult to make a blank statement about one fuel over another. You simply have to experiment for your style and needs to see what works best for you.
Personally, I would only use what gives me the most power performance. I would not be concerned about saving a few nickels.
Stay within the recommended range in your manual though. I can promise they state that range for a very important reason.
SL #7026
VBA #652
HOG #3935417
2011 Viper-Red Spyder RT SE5 & Trailer
2017 HD Ultra Limited
Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
