Thinks out loud
Originally Posted by StanProff
It must be a lot easier to change oil on the SM5 than the SE. I didn't seem to have that much trouble when I changed mine (other than the extreamly tight drain plug on the oil tank). The top bolt on the oil filter was a little difficult to see but that's about it. I'm going home and look at mine again just to see if there is any benifit to the panel.
For those that incorporate Lamont's mod - changing the SE 5 filter gets a lot easier and the new panel will help too.
http://www.spyderlovers.com/forums/s...-filter-(RT-SE)
Repacement Parts Voucher
Originally Posted by Wichita Mikey
Your dealer ripped you off. If you got the letter from BRP the access body is free until May31,2013 upon presentation of the voucher or the dealer can install it for a service charge or free with a oil and filter change.
I just pick mine up today at no charge with the BRP voucher.
These parts only for the RT?
Motorbike Professor
Yes.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Originally Posted by gypsy_100
I just picked up my kit today -- no hassle, gave it to me over the counter, had them in stock. Just the way it should be.......
Did they want the old parts back or did they just hand you the new ones?
Originally Posted by coastrider
I picked up my 2012 RT on 7/3. Has the updated panel been installed at the factory on any of the 2012 RTs, or should I expect a letter from Can Am? My dealer knows nothing about it. I plan to do my own work after the inital service this week. Thanks!
I just did my first oil change on my 2012 RTS. It has the old style panel on it. First time, going slow and taking my time and notes, I was done in 3 hours, including drilling the hole in the plastic support for a long handled 5mm T to access the trans filter bolt. I could do it again in about 1.5, I think. I agree the new panel would have been the shiznit, and would make an oil change about an hour.
Complex..!!
we have an RS and gotta say you all have it rough...three twists and two drain plug and three bolts for the filter done. Although I take lower panels off to avoid oil drips. Glad you got it all set now it will be easier for you next time...!!
2012 RS sm5
Have your dealer put the panels on. If they don't know what it is, tell them BRP has a tech line to call.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Little help...
Question: What if you never got this "voucher" from BRP?
Now what? Is my only option to have to pay for something I should have gotten in the first place?
Any helpful info appreciated. Thanks guys.
PS: I've mentioned this to the service dept at my dealer more than once and each time he had no idea what the deal was. Last time, I even watched him go through his binder with all the BRP bulletins for the bike and he couldn't find anything on it.
Picked up my new oil change access panel and grill
I'm in the same boat. Never got a voucher in the mail. More than willing to just order the kit and pay for it .... But need the proper part number(s).
I believe I heard they only cost around $35.
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
charging alot
Originally Posted by spyder3
Dealer charge is 198.00 labor + oil/filters. 2 book hours.
motorcycle mall just did oil filters and panel for 119.00 on saturday
i was at the motorcycle mall in belleville nj on saturday
Originally Posted by Lamonster
I swear nobody has read or looked at anything I posted in this thread.
i never recieved a coupon from brp so i called them they sent me a letter to present in leiu of the coupon the would not give it to me for free it had to be done with the service so i paid them 119.00 for oil & filters and the panel they normally get 98.00 for the oil change and filters and when i asked if they checked it for updates and all the fluid levels the said that takes more time and cost extra i love the spyder but this dealer is %$%^$ killin me he acts like they are doing me a favor at almost 26 k for this bike i wanna be a crosstown rival so i can close them down ...ps oil change and carwash for my escalade esv at the caddy dealer was 32.00 come on now
i had all that done on saturday
Originally Posted by ulflyer
Folks, I gave the dealer $130 yesterday and heres what I got in return:
New panel installed free,
New transmission cover, filter, O ring,
New filter for motor and O ring,
New crush washers for two drain plugs and a
Grease job for front end.
I furnished my own oil. It also included a bunch of checks: tires, lug nut torque, etc.
Had I skipped these minor checks, which I would have had I understood in advance, I could have shaved about $30 off the price. Seems like a fair price to me.
i paid 119.00 they supplied eveything
Models included for new panel.
What models and production dates are included under the replacement body panel for easier oil change. I just purchased a new 2012 RT S a week ago. Would it have the new panel installed, or will I receive a voucher for the panel?
I had my RTS in for a Tbone replacement in the windscreen motor hinge. The dealer gave me this new package of a lateral easy change oil panel.
The honeycomb part is all that is needed. The lower panel (curves at the shifter) is THE MOST STUPIDEST, F%$$@'n WORST DESIGNED part I have ever seen!
It relies on the upper panel to hold it in. Well what if that upper panel clip was broken... well you cant use this new lower part. IT NEEDS TO BE ATTACHED! with SCREWS! Geesh... come on BRP designers... you can do batter than this! I've see you do it!
Needless to say, I skipped it. easly. Geesh.
RT-S # 352; Timeless Black... faster than any other color. Mods: EasternBeaver PC8 Fuse Box, 12v digital dashboard display, RearTrunk internal Lights.
Pioneer XMP3 hardwired, KewlMetal highway foot rests, PolkAudio Speaker upgrades (dxi525 & dxi400), Custom Garmin Nuvi bracket and wiring, Panel Savers, Custom LED array third brake light and rear signal LED's. Custom mud flap lights. Daytime Running Lights (3wattsx6). Heated Corbin seat with 'Lamonster' cut. JBL 400watt Amp,
Other secret mods.
I too did not receive a coupon or anything in the mail. I wrote BRP about this, and this is their reply. Grammar and such is their fault, not mine.
Thank you for contacting BRP.
In response to your request, the offer to the oil access panel is extended until July 31, 2013. Please contact
your local dealership to get this panel they no longer need a letter or voucher. If your dealer have questions
they can reach us at 715-848-4957.
To find a dealership in your area, please visit our website at: www.brp.com
Thank you for your time.
Jonathan
Customer Service
Service à la Clientèle
BRP
75, rue J-A Bombardier | Sherbrooke | QC | Canada | J1L 1W3
T +1.819.566.3366 | F +1.819.566.3062 | US +1.715.848.4957
www.brp.com
