Yoshimura Exhaust
I bought the Yoshimura exhaust for my 2010 RTS SE5. There is a bolt that has been tack welded in to places. What is the best way to break the tack welds. I am not a welder so I don't the best approach to do this without damaging the exhaust.
Thanks for your help
I used a Dremel with a cutting wheel, no need to cut all the way through the weld, stop before you get into the muffler housing, put your Allen wrench on the screw and turn, the weld will break loose.
