GOS member (Girls On Spyders)
09 GS SE5 Brakes HELP
ok, I'm stuck, literally. Parked the spyder in the garage, set parking brake, shut spyder off, went inside to grab helmet and other items for ride. started spyder, released parking brake, but spyder won't move.
Grabbed a 12mm wrench and a 16mm socket to check out parking brake adjustment, but nothing is doing the trick. No error codes so I believe it's mechanical.?.?
I should add, the parking brake seems loose, it clicks to set it and releases fine but just feels loose.
What do I need to check next? I would get it to the dealer to have them look at it, but as it is right now, it just won't move.
Just went out and started it with the parking brake released ... when I set the parking brake the light flashes on the dash like it's supposed to. I just can't get the brakes to release.
I'm out of ideas.
I'm out of ideas.
Look back on the right side of the rear wheel and make sure the brake lever is releasing. The top of the lever should move toward the back of the bike to release.
It sounds like the caliper is stuck or the cable is stuck. When was the cable and the caliper cleaned and lubed?
Mike
Mike
Roger what Mike in Ga sez.... if the brake lever does not move back when released, it could be a sticky cable, or the inclined cam that pushes the pad could be stuck . Lubing the cable is a good thing...I use a chain and cable lube I got at a cycle shop.
It's back together. Not going to mess with it anymore. Making appt. tomorrow for new brakes and new rear tire. I could use new brakes anyway and my rear tire is almost shot.
Sent from my iPad 2 using Tapatalk
No worries on the 2x4. Spyder is put back together and back to working order. Parking brake works and regular brakes work. It's sleeping nice out in the shop.....
