What do you think of these??
These may be the answer to not showing if turn signals are on:
http://www.ebay.com/itm/EFX-2pc-RED-...ht_4604wt_1180
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Someone else on here already has something like this installed so I am sure you will get an answer soon. My issue is that I find the mirrors already too small so I personally would not like to take up any more real estate on the mirror and used the fender LED's instead.
I also went with the fender LEDs -- can't miss those puppies blinking at you day or night
No doubt; they are a viable option...
You can also contact Muth, and they can do this for you...
Is that mounted behind the mirror then?
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
Yep... just like the ones in the mirrors of cars...
They ain't cheap; but good rarely is!
These mount on the surface of the glass, you don't have take the mirror apart, I just pushed the glass in as far as it would go nearest the bike then drilled a small hole just behind the glass. I will make sense if you look at it. I then removed the mirrors and fished a long zip tie I had and worked out the same hole as the wiring for the turn signal. I connected the wires into the turn signal harness on the mirror side of the disconnect and Bob's your uncle. They will wash out if the sun is behind you so they do not solve the problem completetly but the do help. I have also had several drivers tell me that they seen my signal come and and back off to allow me to turn into the lane so they do get other drivers attention.
Once mounted you will only see a tiny bit of red and white wiring coming from the point of the arror. I put a touch of black paint on wires and they disapper completely.
Good luck
Randy
THESE LEDS
Originally Posted by bmwlarry
Do a search, saw them posted here for $10 and in different colors not too long ago.....also a thread on this outlining similar options.....I have small LED'S on my dash....08 GS......mike
Any reason a person couldn't do this themselves using the above units... just mount on the inside..?
Turn Signal Lites
You can pick them up at PEPBOYS for $10.00 and no shipping.
Gene
