Anyone install a gear/shift indicator?
It's so sunny down here that it's hard to see and I have to look down and low to notice the gear if I forget. Perhaps where the BRP logo is between M and S buttons? Whatcha think?ImageUploadedByTapatalk1341766937.789486.jpg
Thinks out loud
Originally Posted by Tierhog
It's so sunny down here that it's hard to see and I have to look down and low to notice the gear if I forget. Perhaps where the BRP logo is between M and S buttons? Whatcha think? ImageUploadedByTapatalk1341766937.789486.jpg
Just look at your Tach.........if it's ABOVE 5 and below 9K........you're OK
THIS INDICATOR
I'd buy one in a heartbeat, if it overode the STUPID fault message that BRP has programmed into the Nanny.....In my opinion I can't understand why BRP doesn't think you would like to know what gear you are in is beyond my comprehension.....this is because my fault message is false ...nothing is actually wrong....the Nanny only thinks there is ?????.....Do you know if this INDICATOR will tell you the gear even if the Nanny isn't ????.......Also who sells it and where can you get it...????.....Thanks.......Mike....
Motorbike Professor
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Sorry about your dilemma Blue. Nothing is wrong with my instrumentation, I was simply pointing out that when the sun is to your back or when wearing polarized or dark glasses, looking towards the bottom of the panel away from road is less desirable. The brp badge location would be perfect IMHO for an aftermarket indicator with a bright number indicator close to your viewing area. The riser increases the workload too. Might be a mod worth doing on the RS. Will keep you posted.
Originally Posted by NancysToy
Why don't you just get your Gear Position Sensor replaced? The rest of our Spyders tell us the gear just fine.
Learn to count to 5 not that hard 1'2'3'4'5 then down 5'4'3'2'1 then r if needed lol
GEAR POSITION SENSOR ?
Scotty, thanks for your help on this...the reason I haven't done this is I am pretty sure it isn't broken. It usually takes about an hour of riding before this happens and then every code the Spyder has goes off...except for the Limp mode.....and since my X-dealer is less than competant and dis-honest to boot it's not likely I'm going there.....and TEXASRIDE try this out, put a piece of tape over the area that shows what gear you are in.....SEE HOW THAT WORKS FOR YOU.....Then you can report back wether you liked it or not !!!!!!!.........Ride Safe ....Mike.....
USAF '69-'89 E7
Thailand/Vietnam 1972
Member: Royal Order of Rat Bastards
DEAR BRUISER
Why don't you read post # 7. Then maybe you will have a better understanding of this problem before you ***********, ********** Thanks again Mike
THE SENSOR ? PROBLEM
my 2012 RS has one in instrument panel
Wow touch a nerve I have ridden many mc that did not show what gear you are in this is not,rocket science gee lighten up due you gona stroke out .
Motorbike Professor
Often the problems with the GPS don't appear until the unit gets real hot, which would explain your delay. Wiring problems can work the same way, so I wouldn't rule out that, either. A battery or ground issue could trigger such problems. Many faults will trigger other faults in related systems, as the first fault shuts down those systems. BUDS should tell the sequence, though. Your lack of a BUDS trail is odd, and needs to be investigated. If I were you, I would contact BRP Customer Service to discuss the problem. They can put you in touch with their tech experts, who can then instruct the dealer on what to look for. It is fortunate you are not getting limp mode, but this still is a problem that needs to be cured. I can understand your frustration, and your anger at being charged for the diagnosis of what should be warranty issues, but I hope you have the persistence and patience to get this problem addressed and repaired. You will like your Spyder much better if you do.
-Scotty
If your dealer is charging you for hooking up to buds and clearing / checking codes--- then I'd find a new dealer!
Motorbike Professor
I get the gist of your worries now. Having part of the display disappear is inconvenient, to say the least. Still, you should never be seeing "R" at all while in a forward gear or neutral. I still think the GPS is wonky. Given your previous problem with phantom codes, I'd suspect wiring issues again. A second cleaning and application of dielectric grease could help. I'd certainly contact BRP Customer Support and explain that the previous issue has reappeared. If the specify (and authorize) the fix and contact the dealer, it usually goes better. Hopefully they will ask for a wiring harness replacement.
You can get the codes while running...in fact you should get them ASAP while they are active and the warnings are active. For ammunition, I'd take a pic of the warning(s) on the display, then take pics of the fault codes or the blank screen if there are none. That will help in the diagnosis. You may even want to email them to BRP customer service.
-Scotty
FOOTNOTE TO MY FOOTNOTE
Scotty, thankyou,thankyou, thankyou, just so you know I have only these TWO wiring add-on's , both of which were done six months ago..I added a stereo which has a fused power source and ground....and a spliced in wiring harness connector ( that has a convertor specifically designed for MTC. that has separate brake/turn lights )...and neither one of those triggered any problems in the past six months ( 12 mos for the stereo )..this is just info for possible consideration/elimination of the causation......Mike....
If you are trying to prove to the dealer that something is wrong try mounting a video camera so it is watching the dash then go for a ride until the error shows and show the video to the dealer and tell them to explain it.
2013 Pure Magnesium Spyder RS-SM5 Cal Sci medium clear windshield, R-35 hard sided saddlebags and fitments rack, 2013 Can-Am Spyder ST Limited Embroidered Stock Seat, Trunk opening spring, fire extinguisher, Passenger backrest and rack, Added side mirrors, Handlebar bag.
You guys need some beer lol. I have sport bike past, and I fully embrace the spyder platform. On rare occasion I throwback to old ways and the gearshift position light was a welcomed sight on my ZX-6R. I tear up the road on my spyder and simply miss the heads up position of it.
I can count quite well. When I ride, I sometimes take in the scenery and blissfully forget what gear I'm in when downshifting. In addition, I look for a 6th that's not there
It's. 50$ non invasive install...if and when I do it, I'll post it. Everybody have a nice week.
