Originally Posted by joe schmoe
WOW!!! Now that's an AWESOME solution and looks perfectly made for the Spyder!!! However, $585 CDN is VERY EXPENSIVE!!!! and that doesn't include paint!
yes, i should have mentioned, NOT cheap... anyone have these already?
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
Visionary Member
Originally Posted by Double Trouble
You think these look tacky???
YES!!!
2009 Victory Midnight Cherry Vision
2011 Can-Am Viper Red Spyder RT-S
Yup.. they do.
Hot air is hot air ...... you may actually be COOLER by having your windshield UP higher or by wearing a full face helmet. I know when I was riding in 109 degree heat I was cooler with my full face shield down... when I would open it -- it felt like an oven blowing hot air into my face....
This could be a cool option.....
http://entrosys.com/
The Vertica vents are the same ones I mentioned in my earlier post on this thread. The company is called Prestige Auto out of Canada. We ordered these when my wife first began to complain about heat on her new '10 RT over two years ago. By the time we ordered them from Canada, had them color matched, paid the duty on them at US Customs and then paid to have them mounted it was just about $900. The idea is that the air is 'rammed' into the factory vents and forced out through the bottom vent on the RT so that it doesn't collect in the radiator area and fry your leg. We bought them figuring it wouldn't help when stopped or in traffic but on the highway it might make sense.
It didn't. The heat was just as intense, and even may have made it worse. They do look neat on the Spyder however. When we sold my wife's 2010 RT and bought her 2012 Limited, the buyer liked the looks of the vents and liked the 'Ram Air' idea thinking they would help the engine performance. I did nothing to contradict his opinion and that probably helped the sale.
Based on our experience, the Vertica vents are all show and no go.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
Visionary Member
Thanks for the information...It (the Top Vent) looks like it would funnel air from in front, up into the drivers compartment to help with air flow and cooling...But, it's IMPOSSIBLE to tell based on their web site and videos that they SUPPOSEDLY show an installation of them...
Thanks for the info. I just removed the shields below the mirrors and felt that helped with air flow but misses the target, me, so I'm a little perplexed at how being able to direct the air right to the driver with this vertika setup wouldn't help some? So, can you clarify that it doesn't direct the air to the rider? thanks again for the info.
john
Rewaco RF-1 GT
10.57 gallons
I'm not sure how "cool" it would be when i tell the missus it's her or the air conditioner..
anyone try these one of these things? I wonder if they have a dual tubing model.
Rewaco RF-1 GT
10.57 gallons
When the Temps. hit 95+ I park it. I ryde in the mornings and late evenings.
About a month ago I removed my 24" Madstad windshield and went back to the stock RS shorty. Combined with a mesh jacket that definitely solved the airflow problem. I wear a Chill-Towel around my neck underneath the jacket, keep that wet and it helps keep me cool.
THAT SAID... it's a fact that over 95, mesh gear doesn't work. Meaning, any air moving over bare skin-- either over your t-shirt or through your mesh jacket-- is too warm to cool you off. All it does at that point is blow the sweat off your skin before it can do the job of removing the heat from your body. That's why, counter-intuitively, above 95 degrees you should ditch the mesh and wear a closed jacket. Yes, it'll seal you in stifling heat, but your sweat will still work to keep you as cool as you can be (which is, admittedly, not much).
The one exception? If you have a cooling vest that you can keep wet, you can still wear mesh-- the vest will act as "artificial sweat" for your body. But you have to keep it wet or it won't work.
Of course, if you can stay hydrated, OR you can keep the air off of you (a tall windshield will block that air, and keep you sweating), that can also help.
Again, you WANT to sweat. Sweating keeps you cool. If it's 100 degrees out and you're NOT sweating, that's a sign you're in trouble.
The one thing I recommend to everyone NOT to do is to wear a t-shirt/vest/tank-top/no shirt. ATGATT considerations/risks aside, wearing a long-sleeve jacket of some kind helps keep the sun off your skin and keeps you cooler. Last thing you want is heat stroke while riding.
Bottom line: if it feels too hot to ride, it definitely is too hot for YOU to ride-- consider how *you* feel on the bike, you're the one who has to sweat atop it. Be smart and be safe, heat is no joke.
Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
Visionary Member
Here looks like a GREAT solution, that BRP should have down to begin with...
http://www.spyderlovers.com/forums/s...ght-side-vents
It appears that a vortex would draw the HEAT off the motor and UNDER the Spyder and completely away from the rider and from the riders feet...Very interesting idea, now why didn't BRP do this to being with???
Originally Posted by SpyderAnn01
We stopped at a BMW Motorcycle dealer today and the K1600GTL has a cool air wing type thing that you move to allow more air on you then it goes back in place and looks good.
I can attest that those vents on the K1600GTL dump a lot of air on the driver's torso. It would be nice to put those air deflectors under the Spyder's mirrors on a hinge, so they can serve a similar function in the hot months.
- Carl
2017 Can Am F3-L (current ryde)
2015 Can Am F3-S (previous ryde)
2012 BMW K1600 (previous ride)
2016 Can Am F3-T (wife's)
The wife and I went to Chattanooga last night. We took the interstate down and back...Here's the problem. Even doing 75 and 80 MPH, Kathy (Betty Boop) is absolutely soaked in sweat after riding. Granted, it was 100 degrees or hotter while we were riding. She tried adjusting her windshield up and down with no success...However, I was on my Vision and not nearly as miserable or sweaty as she was, on her Spyder...I suggested, that we could take off the clear plastic pieces underneath the mirrors to give her more air. But, she didn't want to do that...
So, my question is: Besides, the baker air wings, are there any other means of directing air onto the driver of a RT-S???
When the ambient temperature is over 98.6 degrees (your body's core temperature), you do not want more air, you want less air. More air does not cool you down, it heats you up.
Thinks out loud
I'm in your camp. HOT is HOT.....HOTTER is not better.
Visionary Member
That makes since, but my thought process was that evaporative cooling would take place with more air instead of blocking off the above 98.6...But I see what you're saying...
john
To install the Vertica set up you have to remove the facgory shields under the mirrors. The air flows into the front of the Vertica device and turns down into the factory vent that is under the mirrors. It does not direct air toward the driver. The ram air effect is supposed to 'Flush out' hot air and it does it's job... it's just that we don't need more hot air flowing out of the vent on the right side or out from underneath.
ah, ok...i thought it came through the vertical device towards the driver or away from...hmmm..thanks.
Rewaco RF-1 GT
10.57 gallons
I was burning up
I have the baker air wings and the heat deflectors listed by our vendors. The deflector for the catalytic converter. The deflector for the right side and opening the panel underneath to exhaust heat from the radiator. The combo truly helps. In the high heat I pour water on my jeans and the air passing over keeps me cool for a good 20 minutes.
That looks like a "cool" system but there's no price and the site is from 2009 talking about preorders for 2010??
Invalid Emails
After reading of others on here doing it, I removed the clear plastic vents under the mirrors just before a 325 mile ride in the heat a couple weeks back. I found there to be a lot more air flow in the waist area than in the past. I am leaving them off till the fall (put the screws back though!) Wont send air everywhere but it does help!
MODS 2013 - Ultimate, Remote / LED Halos, Pete's Dash kits , Elka's!
2011 RT A&C-SM5 - Orbital Blue (mine)
Xenon Lights, Polk speakers (4), 5-LED lamps, fog lights, Sypderpops grills, OGB grips, TIPS and CHANNELZ lights. Seal FLRBDS, Two Brothers Muffler, ZUMO 665 w XM, Gloryders, HMT Brake.
2012 RT-LTD SE5 -Lava (hers)
MODS: Spyderpops chrome grills, TIPS and CHANNELZ lights, HMT Brake, Seal FLRBDS, Gloryders, OGB Grips
Heat
It has been in the high 90s here recently and I once rode through Stockton CA when it was near 110. I found a vest that works great for ryders. It was originally developed for firemen. The vest holds packs in the front and the back. The pack is filled with a non-toxic phase change material that turns liquid at 72. So, unlike some others, you don't freeze body parts as the vest packs keep melting. The packs freeze solid in ice-water in about an hour and the vest loaded packs melt in about the time it takes to run through a tank of gas. On a tour, I keep two very small ice chests. One for pop and stuff and the other for refreezing the vest packs. You start with frozen packs, then swap them out at the first gas stop. I have a double set. Take the frozen set from the ice chest and slip them into the vest. Then put the melted ones in the ice chest. By the time you stop for gas again, they are refrozen. You can keep up this cyle all day. The wing thing just isn't my cup of tea when it's really hot. People have asked me how I can wear an armored jacket in the high temps. The jacket helps to hold the cool in. I've had this thing for 10 years.
GOS member (Girls On Spyders)
I just got the same vest this week and went on my first ride with it yesterday (Sunday). I was praying it would work because just two weeks ago I got heat exhaustion. IT WORKED!!! I like your idea about having an extra set of packs in the cooler. When we all stopped for lunch the best I could do was take the vest off and have the restaurant put the entire vest in their freezer. Didn't work all that well because we weren't there long enough......but it was better than nothing. At the very last stop I poured 1/2 bottle of ice water down the inside front of the vest YIKES, COLD....and the other 1/2 down the inside back of the vest. That worked pretty good because I wasn't horribly far from home. This investment is expensive BUT so is everything we spend on our Spyders.......why not spend something on ourselves so we can ride our Spyders year round? By the way it was only 104 here but very humid.
Tri-Axis Handle Bars
Drift HD 720 digital video camera w/ remote
Russell Day-Long Custom Seat and Driver backrest
BajaRon Swaybar
Elka Stage 1 Plus Shocks
Original Grip Buddies
Seal Floorboards DLX
Two Brothers Exhaust
GloRyders with remote
Zumo 660 GPS
2011 RTS SE5
air flow...
The vents on top of the upper side panels just behind the air deflectors have puzzled me from the beginning. It seems like the air deflectors would create a negative air pressure behind themselves, and actually pull air from under the cowl rather than push it down. It would be nice to know their exact function.
Dave
Never leave well enough alone! (Raymond Loewy)
Motorbike Professor
I believe they are to vent some of the hot air out of the upper body. You can feel the heat come off them going down the road. I have warmed my hands on them in the winter.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
