Results 1 to 18 of 18
    Active Member fencepost's Avatar
    Apr 2010
    Thorn Hill, TN
    Default Pitbull Lift for Spyder
    While at Americade this year I went by Pitbull Motorcycle Lifts, and asked why they didn’t have a Spyder on display? They said that they had never had the opportunity to lift one. I told them that it would not be a problem to lift a Spyder and asked if they would like me to bring my wife’s Spyder RT over to try. As you can see by the picture it was not a problem. What I noticed right off the bat is the Spyder was extremely stable on the lift compared to other motorcycle lifts I have used. In fact other than a motorcycle lift table you would be hard pressed to find a better lift. Improved stability is due to the wider support that comes in contact with the frame along with the overall wheel base of the unit itself. Clearance was not a problem, minimum height is 4 ½” and maximum height is 25”. We did bring the lift in under the left side because Barbwire’s Spyder has SPYDERPOP’S Catalytic Converter Shield Set; if you don’t have this on your RT it is a must to manage the heat coming from the Catalytic Converter. I have ordered my lift and can’t wait for it to get here. I spoke to Tony at Pitbull at (731)644-7432 or their website is www.pitbullmotorcyclelifts.com
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    FYI
    Frame strength and construction:
    weight capacity of 1450 lbs.
    http://www.pitbullmotorcyclelifts.com/facts.html
    Registered Users Mspiv's Avatar
    Mar 2012
    Cape Cod Mass
    I love this as I own a pitbull at I use all the time for my Goldwing.
    are there any landmarks for placing the pitbull under the Spyder.
    Duck
    Michael Spivack
    2007 Goldwing
    2012 RT Limited Lava (traded 5/2/14)
    RT Mods.
    Cup holder, Utopia Backrest, Hi mounter tail light, FZ1 fuse box, aux power outlet, CB and Gerbing outlets
    2014 RT Limited Cognac (purchased 5/2/14)
    RT Mods.
    Cup holder, Spyder Backrest, 2012 CB and Gerbing outlets
    GWRRA
    Cape Cod, Ma.
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by Mspiv View Post
    Have you owned other than Pitbull?? Their price is rather; pricey, but in looking over their literature they are very well constructed an thought out.
    2018 F3-T
    2018 F3-T , Pearl White
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    I do have an RT with SpyderPops cat converter heat shields and also a Pitbull lift. I'm uncertain about approaching the RT from the left, as there are heat shields on both sides. Can you explain in better detail?
    Thanks!
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
    spydee owner
    Guest
    Quote Originally Posted by fencepost View Post
    Which model of lift did you order?
    Quote Originally Posted by IGETAROUND View Post
    That color just doesn't work with my eyeballs...
    What does it say??
    Mar 2012
    Cape Cod Mass
    They are pricey, built very well and the platform is rock solid as advertised. Mine is foot powered. Slightly less expensive. I would do it again.
    Duck
    Michael Spivack
    2007 Goldwing
    RT Mods.
    RT Mods.
    GWRRA
    Cape Cod, Ma.
    Active Member pwilbarger's Avatar
    Aug 2010
    Curtice, OH
    I agree. I love mine. I used it on my GW and now my Spyder.
    Spyder Phyl
    SpyderPhyl
    2014 Cognac RT-LTD, SE6, ACE 1330
    2014 RT-Ltd , Cognac
    Apr 2010
    Thorn Hill, TN
    It seems that my wife lost the left side heat shield or it wasn't put back on when the Spyder was serviced. Called Harvey at Spyderpops and he is sending one out. My wife, Barbwire, has Elka shocks on her RT so the bike sits up higher than stock and clearance is not a problem on either side as the lift support is placed forward of the heat shields. You may need to drive up on a 2 x 4 to get additional clearance to slip the lift under the Spyder if you have Spyderpops heat shields?.
    Jun 2009
    Snellville, GA USA
    I have the Elka's too. Haven't tried putting the lift forward of the heat shield, it suspect that will have the Spyder too heavy at the rear. I'll take a look sometime.
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    Registered Users TuckMiddle's Avatar
    Sep 2011
    Waleska, GA
    Default 2x4?
    I knew if I were patient enough I'd hear the answer to my Q I just asked today. I've got a set of 2X12's parked under my Toyota since I sold my5x10 and got a 6X10 foot trailer that takes the Spyder into the trailer with just the ramp.
    I don't like the car ramp idea for under bike clearance, but I suppose it'd work. Harvey said to go at the Spyder from the front and I asked him in the next e-mail if their BS is ok to jack it up - that's kinda what I think he was saying. No answer, maybe his Spyder is sitting on a bike jack hoisting that bike up by the BS thingy as we speak. More news at 11 or when ever I get it. There is room under the BS for my yellow H. Freight bike jack and it goes a couple inches to the rear of the BS. I do have the ELKAS also.
    Tuck
    SPYDER STALKER tajohn's Avatar
    Apr 2009
    Cleveland, Ohio
    Default Lift
    Ordered P B Lift and mentioned to Tony we are members of Spyderlovers and received a discount.
    Apr 2009
    Cleveland, Ohio
    Default Spyder GS/RS vs the Pitbull lift
    Received the Pitbull Lift, viewed the online assembly viedo (extremely helpful) and am very satified with the product.
    Feb 2009
    Ceresco, Michigan
    I'd like to see some more pics.... close-ups of a Spyder on one of these..........
    Apr 2010
    Thorn Hill, TN
    Sep 2021
    IN
    Since you can't buy a new Pitbull lift can you give me the dimensions of how far apart the 2 lifts are so I might be able to find something close to it for example in this pic Screenshot_462.jpg
    Quote Originally Posted by Rdav01 View Post
    I've seen this type of lift sold under many different brands. They are almost all with the same dimensions. ... I have one from Sears width of support arms is 14 inches outside edge to outside edge. ... works very well, But I suggest you use the " hold down " straps they provide ..... Mike PS .... I've seen these selling for a lot less than the one pictured .....try Harbor Freight .....
