Page 15 of 17 FirstFirst ... 511121314151617 LastLast
Results 351 to 375 of 402
  1. #351
    Sep 2016
    Parma, Idaho
    Quote Originally Posted by napper39 View Post
    yiks oh yeh here i am with my 2cents,rember check your battery cable often it vibrates loose,and a loose cable can be a night mare,check your fusess and relays they vibrate loose,and thats a very bad thing.so lets say you dont chsck these things,you have trouble on the road wont run so you have it towed to a dealer they push in the relay or tighten up the battery cable.if you would have done these things you would not have had to wait for that tow truck,or had the dealer tell you i pushed in that relay and your good to go.so do these things and you might never have any trouble with your spyder ever. have fun and ride like the wind. i do.
    I'm not sure what, or where my problem lies. The 2012 Can Am Spyder RT-S I own, has a display that went dark. The bike can be turned on, but cannot be shifted into any gear. All others things, signals, head, fog, and tail lights work. The fuses are good, the one battery terminal I can get to, has a tight connection. And as the situation left me stranded, I had the insurance company's roadside service come out and cart the Spyder back to the house. I hope, that it doesn't need a new display.
  2. #352
    Active Member Ramg66's Avatar
    Mar 2017
    Star, Idaho
    Thanks Illinois boy, When I purchased my Spyder RT I was fortunate to read this during the first week I had it. I really appreciate you taking the time as it has made my experience so much more enjoyable knowing this important information.
    2016 Can Am Spyder RT-S SE6
  3. #353
    Jul 2016
    Huntsville Ontario
    Default Suggestion
    Thank you for this list of recommendations and for keeping it current. I have a suggestion for us non-US readers. Can you put kph equivalents beside the mph numbers? In Canada our speed limits generally go from 40 to 100kph in increments of 10. ( 40-50 for side streets; 60-70 for main roads; 80-90 for highways; 100 for freeways)
    thanks!....brian
  4. #354
    May 2017
    Boise, Idaho
    Default Do not hide behind the windshield?
    So I am a brand new Spyder owner. I've ridden less than 100 miles on my used 2008 GS SM5. I've done the drills and read the manual. Starting off slow as I learn this new way to ride. I've done some things right and some things wrong already. (Going to shift later and help the clutch and motor live longer!) I don't understand the "Don't try to hide behind the windshield" reminder. Can you give me some context? My used Spyder has an aftermarket tall wind screen which extends out to the grips. On a hot day I get almost no airflow through the vents on my ballistic jacket. I have the original short wind screen. Thanks for the great info. I'm going to check the fuses and battery connections when it comes back from the shop. Thanks again for the info and all of the helpful Spyderlovers out there!
    2008 GS , Standard Seal Floorboard extension with Spyder logo cut out and teflon spacers to raise it. Yellow/Black
  5. #355
    Active Member El Dorado's Avatar
    Jun 2017
    NorCal
    Quote Originally Posted by rosebelle View Post
    Peter, fellow Australian, don't you realize that our vehicles are under less stress than most of the "up and over" world. Something to do with not having to contend with gravity, I've been told before. Our issues are around requiring stickier tyres to stop us from falling off the earth, aren't they
    Thanks for your detail, I'm still asking for actual figures (% of Spyders) where normal (old fashioned?) revs have been used to cause significant failures/premature wear - I was not initially arguing the "against" the higher revving argument. But I see things creep into people's opinion that may be questionable/illogical.
    The point is made, and accepted, that driving in an optimal rev range produces the best power but economy not necessarily so, and what does fuel economy have to do with the subject anyway?
    Silly examples that don't support the argument:
    I've heard aeroplane engines need to rev. on this thread: what 2700rpm is high?
    You have written not to "lug" truck engines at 600 rpm. Who does that?
    How does trucks running at 1200 - 2400rpm equate to faster running engines? For a few examples.
    Often I hear the implied stupid argument that an engine uses the least amount of fuel at the highest torque or power revolutions. Laws of Physics suggest otherwise.
    Not trying to be too picky but "modern cars refuse to select their highest gears" is not universal at all. The ones that I have come across all do go to the top gear quickly. Yes they have learned behaviour controlling gear changes, based on load/throttle position etc, but that is to maintain adequate power, and control emissions.
    You mentioned 4WD I've had quite a few, just looking at a new Prado (top popular 4WD) to replace the wife's. It is offered with 6 speed (2 overdrives), the 4th gear no different to past 5 speed model, strongly suggesting the designers are targeting economy.
    My Mitsubishi Challenger switches to top very quickly, adding a "chip" has created more power and torque but the engine spends even more time at low revs, and with improved economy. No discernible extra wear. Reading 4WD mags , the Internet and Forums don't suggest revving engines at all, on my readings. First 4WD bought new 1983, probably driven 0ne million Kms in them. My various F100/Bronco's clearly ran most efficiently at low low revs (did probably 400,000 Km's in those (bullet proof). I can go on. You did not mention marine engines - tell me about these modern engines! ha
    Tesla? isn't "don't have any other gear choices at all" because they are electric?
    Maybe I haven't learnt the hard way yet. But the last fifty years of extensive driving numerous types of engine things does not support the argument "revving is better", if I am now to argue the "against" case.
    I'm not saying that you should "lug" an engine at all. Sensible driving of course (I understand what has been said and there is some truth in it all).
    Evidence on Spyders, other than anecdotal please.
    You logic seems to use common sense, but one thing that could enter the equation. There has been no mention of how the computer controls the fuel map and timing. could be very possible that excess rich or lean situations can occur the way it is set up. Note, that I have zero idea how it is set up. I do know that running for long times either rich or lean and or retarded or advanced timing can certainly lead to issues. As the rider, We do not have the necessary sensors and gauges to assess those conditions and must assume that keeping it in the suggested power band will have the engine run at its best efficiency either for power, economy or both. I know this is my first post and I am a NOOBIE to this forum and a Spyder owner, but I have had a career in aviation as a mechanic and Aircraft inspector. Those engines have most of that work done by the pilot through RPM control and manual mixture control and to some extent engine cooling, so it is much different.
  6. #356
    Active Member OKey's Avatar
    Apr 2017
    Davis, Illinois
    Default Thanks
    More helpful than you can possible know for new riders like me.
    2014 RTS Limited , Matt Grey
  7. #357
    Registered Users classicvw's Avatar
    Aug 2017
    New Jersey
    Quote Originally Posted by OKey View Post
    Thank You
  8. #358
    Member GrayAuthor's Avatar
    VA
    Default Awesome Thread!!
    Newbie here😀. Thank you so much for sharing your advice!! I am almost finished reading my manual. You have educated me on areas not mentioned in my manual.
    Thxs!
    2017 Can Am Spyder F3 Limited (Black)
  9. #359
    Jun 2017
    Crossville TN
    Default Battery Tender ?
    Would it be safe to have the battery hooked up to the tender with the storage cover on ? Unfortunately it is getting that time of year in the midwest. Thanks
    Dave
  10. #360
    Sep 2011
    North Central Illinois
    Quote Originally Posted by Fire34 View Post
    Dave
    I have mine hooked-up at all times when not riding, with the top-cover on it. That is the smaller cover that only covers the top-half of the Spyder. A full cover would likely not present a problem since it is a tender instead of a charger; however, for myself, I would allow for some circulation if possible.
    SL #7026
    VBA #652
    HOG #3935417
    2011 Viper-Red Spyder RT SE5 & Trailer
    2017 HD Ultra Limited
    Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
    Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
  11. #361
    Active Member bscofield84's Avatar
    Aitkin Minnesota
    Default Great thread
    Really appreciated this thread. Had great info, and answered some of my questions. Thanks much for sharing.
    2014 ST SE5 LT , Black Current
  12. #362
    Mar 2016
    Georgetown, Texas
    Default Can’t move my beloved Spyder
    Any advice on how to get my spyder into neutral when the battery is completely shot?
  13. #363
    Apr 2017
    Wisconsin
    Default Start new thread
    Quote Originally Posted by joemcgriff View Post
    There is a way to do it manually. I thought it was in the owners manual, I searched in my manual with no luck.
    I would suggest start a new thread You will get your answer for sure
  14. #364
    Invalid Emails
    Apr 2017
    bangor maine
    Thumbs up MUST READ FOR NEWBIES
    THIS IS A GREAT POST,I AM A NEWBIE AND WISH I CAME ACROSS THIS SOONER,I HAVE A 13 RT AND WAS RUNNING IT ACCORDING TO WHAT THE DEALER HAD TOLD ME,AFTER READING THIS I LEARNED THAT HIGHER RPMS IS THE ANSWER TO WHAT I THOUGHT WHERE MECHANICAL PROBLEMS.I HIGHLY RECOMMEND THAT ANY ONE NEW TO SPYDER OWNER READ THIS POST. THANKS
  15. #365
    Quote Originally Posted by chewy52 View Post
    Glad you found the thread. Unfortunately a lot of bad information starts with the dealership. Salesman & mechanics that do not know diddly squat. My favorite from here. A group of riders from the lower 48 visited in 2015. Needed work done on one Spyder. Went to the "wrong" dealer. They did not even know where the battery was located. I fixed them up with the "right" dealer. PS. the "wrong" dealer no longer sells or services Spyders.
    Jun 2018
    Sioux Falls SD
    Default New Spyder
    Thanks for the list of things new Spyder owners should know. Picking my new RT Limited tomorrow. Going from Harleys to the Spyder. I hope I like the Spyder as much as I liked the Harleys.
  17. #367
    Feb 2019
    NE ohio
    Thanks!!
    This is a GREAT article, it helped me Immensely.
  18. #368
    Mar 2019
    Maine
    Great information here. I truly have learned a lot.
  19. #369
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    EVERY FORUM should have a sticky like this one. Great job!!
  20. #370
    Active Member SgtRay's Avatar
    May 2019
    El Paso TX
    I just got mine Sat and I'm glad I found this post! Thanks!
    "Friend to those who have no friends. Enemy to those who need no enemies. Headache to those who have no aspirin."~ The Phantom Texter
    2019 F3 s , Neutrino Aurora Accessory Fuse Block Blue
  21. #371
    VA
    I think a lot of the RPM debate is age related. Older people grew up in a time where engine technology was going from points to an electronic module. Engines back then were designed to just cruise around at lower RPM's, and driving styles were laid back.
    The technology in today's engines is amazing. For performance, efficiency, and now emissions, engines are designed to run at higher RPM's. The tight tolerances, quality alloys, bearings, and advancements in oil make the "wearing them out" issue non-existent.
    When my dad went from a 1983 motorcycle to his 2006, I had to retrain him how to ride it. He was trying to ride at 2500-3500rpm. After explaining to him to keep it above 4k, he was amazed at how smooth it was, how much better it shifted, how much more power it had on tap, and how much more enjoyable it was to ride. That bike has 100k miles on it now...all stock, nothing done to it. I "grew up" riding inline 4-cylinders. They don't begin to wake up until 7k RPM. The Spyder is an inline 3. Ride it as such! Not like a big air-cooled twin...
  22. #372
    Jan 2019
    Hunter Valley NSW Australia
    HI Illinois boy.
    Thanks for this post and maintaining it. I've had my 2017 RTL 14 months now and still come back to this post from time to time just in case I missed something. May your rides be long and trouble free.
    2017 RTL , White
  23. #373
    Sep 2011
    Quote Originally Posted by philbtv View Post
    This comment was not to be taken literally, but rather was an attempt to have new riders realize they are not in an enclosed vehicle when riding a Spyder, and the experience is not going to be the same. They should just enjoy the experience of being in the wind. That's all it was referencing. I'll edit it.
    Ride safe and often,
    Illinois Boy
    SL #7026
    VBA #652
    HOG #3935417
  24. #374
    Oct 2019
    Virginia
    This is a great thread. I have been given conflicting information from local mechanics and other riders. Does anyone have a link or site where BRP, Rotax, or CanAm provides this suggested shift point information for the 998cc SE5? My 2013 RT Limited SE5 manual says NOTHING.
  25. #375
    Dec 2012
    Murphy, NC
    I had a 998 cc ST-S before I traded for an F3 with the 1330 triple. When upshifting the 998 shift at 5000 to 5500 RPM’s and you will be fine.
    2020 F3 Ltd
    Spyderpops Bumpskid
