Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Default How do I disassemble the RT mirror housings?
    I'd like to install mirror mounted turn signal indicators on my RT limited but haven't figured out how to open up the housings. I don't want to start prying and possibly break something. Anyone opened these things up that can explain how to do it?
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    Mod Monster Phil's Avatar
    Nov 2010
    Tyler, Texas
    You've got it right. Pry it open
    Read last photo to first.
    Phil, Tyler TX- from my iPad3.5 using Tapatalk HD
    ____________________________
    Phil - Tyler Texas
    2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
    Humboldt SK
    Default I installed mirror LEDs yesterday
    I took a few minutes to look at the surface of the housing that meets with the main body of my RTS. There are 3 clip areas. These clips look like half arrow heads. One for the coloured piece and two for the lower black. I used a screwdriver to release the clip for the coloured piece, then just pulled (folded away from) the main body.
    The lower (black) part, I undid the two clips and pulled (folded or hinged) that part away.
    Then I undid the three screws that held the front LED unit in place. No need to disassemble further.
    Turn the unit around (look at the mirror side) and you will notice an existing hole in the plastic underneath the outer edge of the mirror. This is where I ran the wires for my new LEDs. On the Spyder the black wire is the ground and the non-black or striped is the hot.
    Hope my description helps.
    Very Active Member captblack's Avatar
    Oct 2011
    Woodbine, GA
    You don't need to disassemble the mirror - just drill a small hole for the LED wires and fish them down through the assembly. There are a couple of threads on here that explain it.
    I did mine that way and it was pretty easy ...
    Bill
    Pride Runs Deep Semper Tacitus
    An armed man is a Citizen; an unarmed man is a subject....
    2017 F3 T SE6
    2015 Vulcan Vaquero ABS
    ALR Chapter 401 (Hilliard FL)
    GA & FL Patriot Guard
    Even prying them apart; there's a lot of room in the process for breaking off the tabs... Please proceed with great care and caution. Lots of patience will win the day!
    Aug 2010
    Cloquet Mn
    You shouldn't have to drill any holes, there is a large hole on the inside mirror housing that you can run the wires through. Once you get the covers off then you can separate the mirror housing and the mirror will move back about an inch, then run your led strip on the mold line.
    Apr 2012
    Phil, Where did you find these instructions and pictures? I've looked through a large portion of the service manual and can't find them. I also looked through the operator manual without any luck.
    Active Member sinkhole's Avatar
    Jul 2010
    Huntsville, Al
    Default RT mirrors...
    This may give you some idea of where the locking tabs are located. As others have said, disassembly is a stinker. Proceed with caution.
    Dave
    Never leave well enough alone! (Raymond Loewy)
    Thanks for the excellent picture!
    Very Active Member GeoffCee's Avatar
    Dec 2010
    Telford, UK
    It is probably very satisfying being on the mirror assembly line at BRP.
    Click, click, click and there, the mirror is quickly assembled.
    For the owner, though, pulling them apart again is sort of counter-intuitive in the way you have to poke around blind with a screwdriver and prise the thing apart like a stubborn shellfish. Breaking off those unforgiving tabs is way too easy. You will never be ready for that to happen but chances are it will. I speak from experience, of course.
    Opening them up can be achieved if you have a lot of time on your hands and you are overloaded with the patience of the Man in the Moon but in my view it would have made a much easier and quicker job to have had some neat little screws to undo instead of fiddling about with those pesky break-off tabs.
    Just saying...
    2011 RT-S SE5, Acumen Tempest Cat-1 Alarm, SmoothSpyder Belt Tensioner,
    Autocom Super Pro Auto, Garmin Zumo 550 BT, 10amp Socket, Front Fender LED's,
    Grip Puppies, Spyderpop Belt Guard, Nautilus Horn, Shortee Antenna, BajaRon's Swaybar,
    Cree LED Day Running Lights.
    Nov 2010
    Tyler, Texas
    Quote Originally Posted by DR Buck View Post
    I bought the chrome accents for the mirrors and those are from the sheet that came in the package. I know, I cheated
    Phil - Tyler Texas
    Jul 2010
    Huntsville, Al
    Default screw it...
    Quote Originally Posted by GeoffCee View Post
    Just saying...
    The best thing BRP could have done on the RT would have been to screw the mirrors on. Those crazy loose fitting pins, and vibrating mirrors drive me cwazy.
    Dave
    Well if anybody busts them up; I've got a spare set in Blue that somebody can have if they need them...
    Jun 2011
    Near Lexington, NC
    I got mine apart the other day to wire LED strips that I attached to the lower part of the mirror. Can't even begin to tell anyone how to do it. I was lucky and didn't break any tabs and its great seeing the LED's light up when the signals are one. Much nicer than squinting at little green dot in panel to see if I turned the sig off or switched it accidently to other side.
    Apr 2012
    Well the clips on the chrome covers break real easy. Velcro used to put it back together.
    Apr 2012
    Got the 2nd side done without incident.
    Registered Users JJW SpyderRider's Avatar
    Jun 2010
    Rockton, IL
    Quote Originally Posted by captblack View Post
    This is what I did Saturday. I drilled the top corner then fished the wire to the bike side of the housing. I added the < and > indicators. Warning: The plastic cover is not held on very well. I used liquid black tape to seal the light and hold the cover on better.
    RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
    Member of the WSR (Woodstock Spyder Riders)
    Jun 2011
    Near Lexington, NC
    Just saying...
    +1. I did mine, but it was a real SOB. I wouldn't do it again knowing what I know now.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    May 2009
    Connecticut
    No Need to take mirror apart- Drill hole-Get wire to lower clip opening-Drill small holes through walls on the inside.
    Sea Doo GTI-SE 90 Jet Ski!!
    Bethel
    I have a question that is related to this. I took my mirrors off in the process of installing new headlight bulbs and I am not satisfied that they are reinstalled correctly. The left side snapped right into place, but the left side doesn't seem to have tightened up on the one of the mounting screws. Anybody have any suggestions?
    Ryde On!
    R & B
    May 2009
    Connecticut
    Probably the Lower Front Pin- Takes Time and Practise- When you get it you won,t forget it!!!
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    use nylon string, like grading string, and your shop vac ,put the shop vac on your mirror where the wires come out, you will be amazed at how fast that string flys thru the mirror housing, then attach the led wires to the string and pull them thru. sorry I forgot to say you still have to drill the hole where you want it
    Aug 2015
    Cleveland, GA
    Default mirror disassembly
    Phil:
    I would like to read the entire section in the Shop Manual, since I broke two tabs "gently prying apart" the covers from one mirror on my 2014 RT-Limited (chrome garnish cover).
    Before I do any more damage on the second mirror, I want to read a little more to arm myself with knowledge.
    I have the "Green Book" electronic PDF and in the "Chassis" section where all the body panels are described, I find no mention of mirror dis-assembly. Searching various related words (e.g. "mirror cover removal") hasn't been productive.
    Any help will be appreciated, thanks.
    Pete
    Quote Originally Posted by Phil View Post
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Just saying...
    Having had the same experience, I will say that you gave an excellent description of the patience required for this process. (I didn't have enough when I attempted it.)
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
