Registered User
Auto Clutch Damage
Most of you know but its worth repeating. We are seeing (via diagnostic reports on our customer units) many Spyders that are being riden below 3000rpms during cruise. This is BAD,BAD and BAD. It can result in complete failure and destruction of the clutch. Critical with the auto clutch that cruise is above 3000rpms to prevent the clutch from sliping which results in heavy wear,heavy heat and failure. We just had one in where the friction plates expolded and it was a mess. After B.U.D.S diag on the machine we found it was run below 3000rpms nearly 50% of the time. NOT GOOD! We are starting to see this of late thus I thought I would send out a little note for those that may not know.
Jeff
[/URL]
Mod Monster
Great reminder Jeff. I am now a reformed <3000-er.
Phil, Tyler TX- from my iPad3.5 using Tapatalk HD
____________________________
Phil - Tyler Texas
2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
Blazing Member
5500 almost all the time .
Motorbike Professor
Thanks Jeff! I have been preaching about this for a while now, and so has Lamont. It's nice to hear it from a pro. You are a valued resource to this community. I hope our members are listening.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Well I'm one of those "Low and Slwo" guys... I'll see if I can bump the rpms up a bit... Thanks!
Originally Posted by SPYDERJEFF
....many Spyders that are being riden below 3000rpms during cruise. This is BAD,BAD and BAD. It can result in complete failure and destruction of the clutch.
Jeff
I don't preach, just ryde
Jeff, would BRP like this RPM profile?
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS
Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
SpyderLovers Sponsor
Jeff
are you just reffering to setting the cruise control at the 3k mark or riding the spyder at 3k or less? but what if your are stuck in traffic or just riding around the neighborhood going nice and slow how does this effect all this? just clarify all of this i don't want to be doing something i shouldnt be doing. thanks
Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
Why don't they reset the computers so it downshifts earlier?
AFAIC thats the point of having an auto trans that downshifts when needed.
They're probably ready to put you on the roadrace team... if it ever happens!
Docdoru - how do you get that diagnostic graph? Gotta have access to the BUDS software?
MODS 2013 - Ultimate, Remote / LED Halos, Pete's Dash kits , Elka's!
2011 RT A&C-SM5 - Orbital Blue (mine)
Xenon Lights, Polk speakers (4), 5-LED lamps, fog lights, Sypderpops grills, OGB grips, TIPS and CHANNELZ lights. Seal FLRBDS, Two Brothers Muffler, ZUMO 665 w XM, Gloryders, HMT Brake.
2012 RT-LTD SE5 -Lava (hers)
MODS: Spyderpops chrome grills, TIPS and CHANNELZ lights, HMT Brake, Seal FLRBDS, Gloryders, OGB Grips
Request print from Service.
Shut up and Race!
Jeff
Coming off a Harley Street Glide, it took me a while to get used to the high RPM’s of the Spyder. Shifting early is a hard habit to break.
Current Bikes:
2018 BMW K1600 B
2012 Spyder RT LTD - Sold
2003 HD VRSCA (VROD)
I went the opposite way 'Spyder to a Tri Glide, Keept on bounceing off the red line, So i did a stage 1 to bring the red line to 63 hunderd.
Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
You don't count Doc because you don't have a throttle, just an on off switch! You ride like it was the space shuttle! Once it's switched on it's 100% and there is no shutting it off!
Originally Posted by daveinva
I always chuckle at the RPM threads because there are always people defending running the Spyder at low RPMs. Ummm, this is what happens when you ignore the manual, folks. (Not to mention our advice!)
Look, I know we're all focused on gas mileage (that stuff ain't cheap). And for some new riders, they come from a low RPM world and for some reason wish to stay there. Maybe they're just not wearing earplugs?
Don't lug engines. Lugging is bad.
The whole idea is to ride the machine the way it was engineered to be ridden. Running a Spyder at 3,000 RPM will give you the same effect as running a Harley at 7,000 rpm, BUSTED STUFF!
It's your ride so do what you want, just don't complain if you ignore the manual and it doesn't work out for you.
Try riding a Harley at 7 grand day in and day out and then complaining to your dealer when it breaks. Guess what he is going to tell you! Same-Same for the Spyder only in the other direction.
OK, I have been thinking of saying this for some time, so here goes. Scotty is right...he, Lamont, myself and many others have posted about riding the Spyder with the trans in the wrong gear (like 5th gear doing 30 mph) and claiming that the Spyder runs just fine. But, like it was posted, it's your ride, so when the trans or whole engine goes belly up, don't complain about how trashy the Spyder is.
A person spends over $20,000 for a Spyder then complains about how much gas it uses, how fast the rear tire wears out, and the cost of the up keep, etc. If you can't afford the tires or the gas or the up keep, why did you buy the Spyder? Like anything else we own, we have to budget our Spyder needs. Complaining about it won't change the fact that the Spyder is what it is.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
One more thing about short shifting and low revs...I read an article recently about a service manager working on a Triumph Thunderbird, it was making a clanking noise when running. Pulled the engine, pulled the head, carbon built up on the pistons to the point the valves were contacting it, caused by not blowing the cobwebs out. Tractors can run slow, what we ryde can't.
john
You have to operate the machine as designed or you're not going to be happy with the results.
For example, I used to ride a fast street bike on my days off and drive a fire engine at work. I rode the street bike hard with the throttle wide open all the time, but with my fire engine.... Oh, wait.... Not a good analogy! Sorry, forget what I said....
Thats right I was a fireman for 34 years and beleive me he drove the fire engine the same way he did the MC.
Hey now! Public safety and the safety of my crew always came first!
Ok, well, it was right up there near the top....
Hmmm.... I am sure it was somewhere on the list... now, where is that list...
