Mr Gene what a lovely avatar picture of you. You probably won't need your rain gear in Albuquerque unless you are in the oath of a fire hose.
I wear a mesh jacket and pants and I stay pretty coil. I use a camelback filled with ice water to drink while riding. We just got these neat little skull cap things called Heat Out which you wear under your helmet and they do a good job of keeping your head cool.
If you don't west a jacket you are better off with a long sleeved shirt than bare arms. The most important thing is to drink plenty of water.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Camel back best investment I made for desert riding. What you don't put in you , you can dribble down the front of you for additional evaporative cooling.
Who makes the Heat Out caps?
Cycle Gear sells their version of the Underarmour heat gear, called Heat Out. I wore the skull cap and the shorts this weekend and really like them. I have the UA gear also, and prefer the Heat Out.
I wear a thin long sleeve bright white shirt to protect my arms from the sun. The brighter the better, as it will reflect more light and therefore heat. I can't help but feel things like mesh jackets will still be too hot in the desert sun, especially if you are stopped for any length of time.
I used a "cool vest" under my shirt over the weekend and I must say it kept me cool, though my body felt clammy and itchy as a result, but it did keep me cool. Not sure if I would have preferred the heat. Regardless, drink lots of water and keep drinking it.
This may sound silly, but there are two ways to die in the desert. The first is of thirst. The second is by drowning (flash floods).
I didn't see the Heat Out shorts at our Cycle Gear but I'm definitely going to go back and look for them. Cycle Gear stuff is available online if you don't have a store near you. The heat out caps were on sale for $5.00 normally $9.99. My Spyder thermometer read 118 on Saturday and my head was dry when I got home.
2010 RT- 622
Check out thehttp://www.ldcomfort.com/ LD Comfort site : The clothes they sell help in hot weather and general comfort in riding. I have bought from them and they have great service. Hope this helps.
If you pee, drink a bottle of water. If you don't pee, drink a bottle of Gatorade and a bottle of water.
Funny but so true!
2010 RT- 622
Don't know what to say, I live in AZ where it gets to 120 but all I wear is pants and a t shirt. Lather up with suntan oil and away I go. I agree with the lots of drinking water. Also I take pour-on water for the bod. Been to Albiqurk. N.M and its lots cooler than here, you should not have a problem. Have a great trip.
I agree with ArrMiHardies that, short of a cooling vest of some kind, a long sleeve white shirt is the coolest thing you can ride in. They're even cooler if you wet them down but the dampness won't last long. We used to ride in them but I've come to believe that the protection of a mesh jacket is more important than being a little cooler. We just changed from some dark blue jackets to silver which seems some cooler. I like the cool vests but the Joe Rocket vests we own have gotten to where all the moisture drains out the bottom rather than staying up in the vest until it evaporates. Gonna have to get some new ones. I also like the gel neck bandanas that Yazz mentioned. It's amazing what a difference just keeping your neck cool can make.
I have ridden in short sleeve white T-shirts (when I was young and dumb and thought I was bulletproof) but if you are prone to blistering at all that is NOT the way to go. A bright sunny day with 10% humidity and riding into the wind at 70 MPH will cook you before you know it. On the RT a good pair of boots will help to keep your right foot just a little cooler.
Hey Gene, this is what we do going through the desert...
Stop every 70, 80 miles. Go to the restroom. If you pee, drink a bottle of water. If you don't pee, drink a bottle of Gatorade and a bottle of water.
No serious partying the night before. It dehydrates you...
Also, those neck bandanas with gel in them that cools you off works wonders!
Our marching band advice was: if your pee is dark yellow drink more water, pale yellow pee is the best! The kids loved when we would do the "pee talk" every year!!!
[SIGPIC][/SIGPIC]Spyder Owner Since June '08 & April '12
Ms. Ann01From Michigan to Nevada is quite a climate change.
Since you are out and about in the heat could you share Hot riding gear info.
What are some of the do's and Don'ts on a day long ride.
Hopefully
Anyone living in the SW can add information helpful to the crowd headed to Albuquerque.
Ride Nekkid!
Ann01I ordered a heat cap.
Yazz
Geezz you can't say P_ _ on spyderlovers. OK OK if you saw me drink 2 Gatorade's what would that mean.
I have a neck jell
Sam
ordered up the LDcomfort shorts---they look great.
Ann01
Don't encourage Yazz to share more.
Butch and Paula
Enough already with the marching band info--(I hope Yazz misses this)
It will be good visiting in Durango
Maybe talk about a trip to the Grand Canyon since we're that close.
FireFly
Are you headed to Durango? I'll bring my camera to document your hot weather gear.
I'm benefiting from the info as are a number of spydelovers--
THANKS ALL
I wear a long sleeve demin shirt (purchased from Cat Specialties) over any shirt and every time we stop about 100 miles...I take the demin off and soak it down with water....drink lots of water as said before.....the hotter it is ... the longer the stops...
I assume the Camelback is worn outside the mesh jacket. Is it cumbersome? I've been looking at a 3 litre version and wonder about that plus the jacket's armor.
kt
kt
Ken, we bought cheap ones before our trip to Spyderfest. Joe threw his away on the return trip because it leaked. He then bought an authentic Camelback 3 liter and he loves it. They are worn on the outside and no they aren't at all cumbersome. I have a full face helmet and it is really easy for me to drink and drive with it. The tube lays flat and doesn't fly around.
Gas stations even let us refill them with ice and water from their soda machines and didn't charge anything.
2010 RT- 622
I have the water bag inside the back pack with the addition of the inslated pouch you get in the mail.
With the back pack comes storage for sun glasses and credit cards etc. At gas stops I use the cap as a support for the seat makes it less of a struggle.
I shared this with Deb and Brian on their way to Calf-------miss those two.
Bikeguy I am not "young and dumb" but I still ride in T shirts. Am 79 far from young and have been riding for 67 years so far from dumb, its a matter of choice in my eyes. So if you have more riding experince than me let me know the wisdom of it. Till then don't call people who ride different than you "dumb"
I said I was dumb, not you. I don't care what you wear. The fact is, I'm a lot more interested in saving my skin than yours. I'm only 74 and only been riding 62 years so you've got more years than me but I don't know about experience. I've lost enough hide in the dirt and a little on the pavement to know that I don't care to lose any more. Although, the point I was making, that you apparently missed, was that sun and dry wind, and heat would blister you in a hurry if you have any tendency to blister. Now, if you care to, you might tell me how my comment about riding in a T-shirt when I was younger and dumber managed to insult you.
