Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 145
  1. #101
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by ClayL View Post
    I have a copy of the new maintenance schedule. If I can get to a scanner I will try to post it. Interesting.....it says it doesnt apply to bikes registered in California.Regards,Clay
    Is it some place where we can pull it off the interent?
  2. #102
    May 2012
    SoCal
    Default New Maintenance Schedule - Have copy
    Quote Originally Posted by wyliec View Post
    I have a paper copy....... havent noticed it out on the net......Clay
  3. #103
    May 2012
    Pelham, Alabama
    Default New filters and 600 mile service
    I took my 2012 RT Limited in for the 600 mile service today, well dropped it off and will get it back tomorrow.
    Before I left the dealers service dept., they gave me a copy of the Repair Order, it did state that the New part #
    oil filter will be installed, but, nothing listed on the Order to change/replace the HCM transmission filter, new or old part #'s.
    I left my owner's manual in the frunk so they can make the proper dealer notations in the manual, so now I can't
    check the maintenance schedule to see if they ARE or ARE NOT suppose to change out the HCM filter on this service!
    Also, the service guy informed me of a SB#2012-6 Spyder RT inspection Possible water infiltration Radio Module (warranty)
    Just to give all a heads up on this possible issue.
  4. #104
    Mar 2008
    Allegan, MI
    Quote Originally Posted by 3leggedSpyder View Post
    The HCM filter is now supposed to be changed at every service interval. It previously was every other one, but that was changed by Service Bulletin. Your dealer doesn't seem to be on top of his game.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
  5. #105
    Active Member aklim's Avatar
    May 2012
    Hartford, WI
    Quote Originally Posted by NancysToy View Post
    I'm a little puzzled by that. After all, the HCM filter gets the same oil as the oil filter so why would you change it every other one?
    2017 F3 Limited , White
  6. #106
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    And I wonder if they've even bothered to pull the oil tank screen and clean it???
    That one I do every other oil change....
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
  7. #107
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Quote Originally Posted by Firefly View Post
    Did you ever find any thing in the oil tank screen?
    Mike
  8. #108
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by MikeinGA View Post
    Mike
    I never did, But thats a good thing right?
  9. #109
    Active Member kentompkins's Avatar
    Jan 2008
    Absecon, New Jersey
    Here's a link to a .jpg file in my Dropbox. There is a download button in the bottom right corner.
    https://www.dropbox.com/sh/ebg0olol5...il_Filters.jpg
    ken tompkins
  10. #110
    Jul 2011
    Mitchell, Ontario, Canada
    Default oil tank screen
    The oil tank screen is there incase you accidently drop in something when topping up the oil.
    2018 F3 LIMITED
  11. #111
    Mar 2008
    Allegan, MI
    Mike
    Yes!
    -Scotty
  12. #112
    May 2012
    Pelham, Alabama
    Default NancysToy
    Can you tell me where I can find and print out a copy of the Service Bulletin for this change.
  13. #113
    Mar 2008
    Allegan, MI
    It is Service Bulletin 2010-1. I don't have a copy, but your dealer can pull it up using that number.
    -Scotty
  14. #114
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Had my 665 gps installed today and decided to have them change the oil while up on the rack including the screen which i don't think had ever been checked. Very little debris on the screen, the two magnetic plugs had some debris on the nipples so they did there job nicely. Also had them pull the green air filter which was dry with some debris in it. Blew it out and was good to go.
    THe new filters are backordered according to my tech and BRP is taking back any "obsolete" inventory. I had him install baja Rons filters and amsoil.
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
  15. #115
    Mar 2008
    Allegan, MI
    Quote Originally Posted by spyder3 View Post
    If you have the aftermarket Green Filter (name brand) it is an oiled filter and is not supposed to be dry. You need to clean and oil it with the materials in their maintenance kit, just like a K&N. If it is an OEM filter, it is dry, but blowing it out can damage it...it is better to replace it.
    -Scotty
  16. #116
    Apr 2011
    Burlington, NJ
    Its the green high performance air filter scotty. I guessed it was going to be saturated with oil(i suspected my last oil change was overfilled) but was it wasn't. Bad choice of words using "dry". They didn't have the cleaner or the spray used for that filter and the kit i bought didn't arrive until after i got home today...but now that i see how to get it out, I will treat it with the proper materials. It only has 3k on it anyway. Thanks for the heads up of course.
    Rewaco RF-1 GT
    10.57 gallons
  17. #117
    May 2012
    Hartford, WI
    Weird. My dealership has them in stock since monday and they sent all the old stuff back.
    Not sure about the oiled filters though. Supposedly some have said that the air running past it eventually pulls enough oil to screw up the MAF. IDK
  18. #118
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by aklim View Post
    Some people think if a little oil on the filter is good, a lot is better. If you oil them properly with the correct oil you'll be fine. I'd say you'll get less oil residue from this kind of air filter (properly done) than you will from an unfiltered crank case vent about 2" from the intake!
  19. #119
    Mar 2008
    Allegan, MI
    A MAP sensor is not like an O2 sensor...a little oil won't hurt it.
    -Scotty
  20. #120
    Apr 2011
    Burlington, NJ
    Default cleaning the green performance filter
    Rewaco RF-1 GT
    10.57 gallons
  21. #121
    May 2012
    Hartford, WI
    I didn't tear it apart yet but that means we are speed density and not MAF?
  22. #122
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by kentompkins View Post
    ken tompkins
    I was looking for what ClayL mentioned in post #100 and also what was asked in post #94.
  23. #123
    Jul 2011
    PA
    Default Photos of Filters
    Picked up my new filter today. The filtering media is white rather than yellowish and the wire mesh is not just around the outside but goes in and around each fold of the filter media. Weighs 80% more than the old filter.new.jpgold and new.jpg
    As I said in an earlier post, the old price was $15.49 and the new one lists for $19.99.
    RT and Gold Wing States & Provinces
  24. #124
    Dec 2008
    Syracuse, NY
    What about the other mainterance items other that the oil change? Is it still 3,000 6,000 9,000 and 12,000 miles or 4,600 9,200 13,800 and 18,400 miles for the all items including oil change?
    I would like to see a periodic maintenanace schedule like the one in the manual. I would not want to lose my BRP warranty or my extended warranty. That's IMHO.
    Mike
    Has anyone been to their dealer yet for the new oil filter and asked the above question?
    MikeinGa,
    Have you found out anything?
  25. #125
    May 2012
    Hartford, WI
    MikeinGa,
    Yes I have. They don't know much about it other than what is here or that it is new and improved.
