Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 145
  1. #26
    Registered Users redroC's Avatar
    Mar 2011
    Houston, TX
    Quote Originally Posted by NorthStar View Post
    One of my dealers has received a stock of the new filters and HCM covers already. If you buy the new HCM filter, the first time you will also be supplied the new cover. This arrangement applies until May 2013.
    I plan on picking up the new HCM filter and cover the next time I pass by the dealer. In the meantime I will use up my stock of old filters.
    Did they mention any kind of price change?
    Just curious.
    Romney & Boyd
  2. #27
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    Quote Originally Posted by spyder3 View Post
    The older one says obsolete on it..
  3. #28
    Active Member aklim's Avatar
    May 2012
    Hartford, WI
    With a 2012, it should be standard now, right? Last time I changed it, it does look like the 35mm cap for the HCM.
    2017 F3 Limited , White
  4. #29
    Dec 2009
    Canada
    Quote Originally Posted by redroC View Post
    Just curious.
    I don't think that there has been a noticeable price hike. The new filter price sounded vaguely familiar to what I paid for the filters I bought late last year.
  5. #30
    Registered Users Mspiv's Avatar
    Mar 2012
    Cape Cod Mass
    My dealer says:
    "They will be superceding the old numbers to the new ones so the new style will be the only ones we will be stocking."
    Duck
    Michael Spivack
    2007 Goldwing
    2012 RT Limited Lava (traded 5/2/14)
    RT Mods.
    Cup holder, Utopia Backrest, Hi mounter tail light, FZ1 fuse box, aux power outlet, CB and Gerbing outlets
    2014 RT Limited Cognac (purchased 5/2/14)
    RT Mods.
    Cup holder, Spyder Backrest, 2012 CB and Gerbing outlets
    GWRRA
    Cape Cod, Ma.
  6. #31
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Thanks for the update Lamonster. The HMC larger filter is a good idea. With a good full synthetic oil, are they really needed? When I use up my supply of filters that I got from BajaRon, I hope he will have the new HMC filters in stock. That's IMHO.
    Mike
  7. #32
    Jul 2011
    Mount Airy,Ga.
    The engine oil filter is the same size and appears to be the same filter material. What is the difference?
    The price?
  8. #33
    Jun 2010
    Memphis, TN
    Is this just for the 2012-11 Spyders or can we also use this filter and schedule for our older Spyders?
  9. #34
    May 2009
    Connecticut
    Theres Nothing Wrong with using up our old filters -- Its just that with the New Updated versions you will have
    "BRP,s Blessing ?" to go 4,600 miles between changes.
    Sea Doo GTI-SE 90 Jet Ski!!
  10. #35
    Arkansas
    Ha! Wouldn't you know it. I had my 3,000 mile service last Friday. I looked on the invoice and old part numbers. Oh, well.
  11. #36
    Springfield, MO
    One thing for sure is the new filters have steel reinforcement.
  12. #37
    Jul 2011
    Hanford, Ca.
    Was at the dealer today to get the break pin installed, they didn't mention this but then again they didn't know about the pin recall either. Thanks for the heads up Lamont.
  13. #38
    Registered Users bo9roadking's Avatar
    Apr 2012
    San Antonio, TX
    I'm getting my 600 mile service done this weekend. The dealer says they don't have the new filters yet, so I'll be using the obsolete one at least for this service interval. At least the "obsolete" filter still works. Thanks for the info Lamonte.
  14. #39
    Mar 2012
    Black Canyon City, Az.
    Default New Filter Notification
    Thanks for the info. How or where does a person find out this info? Does BRP send it out to everyone?
  15. #40
    Jul 2011
    PA
    Default Valve Adj Requirements
    Quote Originally Posted by Lamonster View Post
    Service 2012-11
    There is a new Maintenance Schedule that was just released for all Spyders that change the valve inspection time from 10,000 miles to 14,000 miles.
    The old spec was first at 6K miles and then every 12k thereafter (or 10,000km and 20,000km respectively). Not sure where you're coming from on the 10K and 14k mile numbers. Can you clarify? Thanks.
    RT and Gold Wing States & Provinces
  16. #41
    Springfield, MO
    Quote Originally Posted by gypsy_100 View Post
    You are correct, got my miles and K's mixed up.
    Adjustment intervals can be increased to 22,500  km (14,000 mi) and eliminate the inspection at 10,000  km (6,000 mi).
  17. #42
    Quote Originally Posted by zrc View Post
    No one has asked the obvious question here...
    How does this effect Bajaron!!!
    I didnt even know dealers sold filters
    There are 3 possibilities...
    1- It doesn't make that much difference (not likely)
    2- It makes a big difference but I am able to sell my current stock (maybe)
    3- I have a lifetime supply of filters I can use (engine) and many that I can't (trans)
    I wonder if the Aprilia motorcycles that have been using the same engine filters since before the Spyder was built (Same engine - Same filter - SM5) is also changing to these new filters, or is it just our Spyder.
    The Aprilia ran several years with an even smaller engine filter than what our Spyders use (the older ones still do) and they develop about 50 more HP than our Spyder with the same motor.
    I think the larger transmission filter is a good move, but my feeling is the engine filter is not going to be a real world improvement. I will continue to run them in my Spyder.
  18. #43
    Feb 2009
    Ceresco, Michigan
    Just put my last oil filter on..... Will continue using Ron's filters for the foreseeable future. I run my engine pretty hard...so I'm sticking by the 3,000 mile rule.....about every 3 weeks for the next few months.
  19. #44
    Invalid Emails
    May 2011
    Gulf Coast of Texas
    Default Sure Glad I have a lever instead of a paddle
    So now you'll need to add a thimblefull more oil to compensate for the 13mm more capacity. Amazing how the engineer developed this calculation from less than a 1/2 cup more oil to over 1600 miles. Guess they got bored trying to figure out an easier way to put air in the rear tire..
  20. #45
    May 2012
    Hartford, WI
    Quote Originally Posted by Schnauzer View Post
    13mm is a length and not the surface area that has been increased. Larger surface area = larger filtration surface = longer lifespan.
  21. #46
    Active Member spyderyderjim's Avatar
    Feb 2012
    Tucson, Arizona
    Default BRP needs to put "spin on" oil filters on Spyder motors
    Why doesn't BRP put "spin on" oil filters on engines in Spyder's? Every modern motorcycle engine has "spin on" oil filters that are very easy to change!!! BRP could offer a kit to convert to spin on oil filters. Jim
  22. #47
    Invalid Emails
    May 2011
    Gulf Coast of Texas
    Quote Originally Posted by aklim View Post
    1"x3"=1/2 cup more oil...someone asked about additional capacity. I have the SM5, so not really sure how much fluid to fill the SE5 Tranny.
  23. #48
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    Exclamation planned obsolesence
    so is this new schedule really just to sell more bikes? don't know if I'd feel comfortable running blend, in Texas heat, after break in full synthetic would offer adequate protection.
    2014 RT SE6 LTD , White
  24. #49
    Quote Originally Posted by kinggeek View Post
    I just bought 4 sets of the old filters and seals from Ron last month!
    As far as I know, no one has had any issues with these HiFlo filters. The HiFlo transmission filter flows more oil than the OEM filter (though it won't flow as much as the new larger filter).
    If BRP had not come out with new filters everyone would still be fat and happy with the current products.
    It will be interesting to see if anyone sees an improvement with the larger transmission filter.
  25. #50
    arntufun
    Guest
    Quote Originally Posted by Firefly View Post
    You better buy at least one filter from your dealer before may of 2013 to get that free cover, because after May 2013 I guessing it will be a $150.00 part.
