Results 1 to 7 of 7
    Active Member 2 Stricklands's Avatar
    Hardy, VA
    Default Sena Speakers wont stay in helmet
    Hi all
    I saw and heard a lot of positive comments about the Sena Bluetooth headsets, so at Spyderfest I bought a dual set. They work fine, but the speakers will not stay in the helmet. There is a thin piece of plastic that is velcro like on one side and smooth on the other. The velcro side stays in the helmet, but the other side will not stay on the speaker. It looks like it was glued and the glue is still stickie. Every time (every time) either of us remove our helmet the speaker falls out and is hanging by the wire. The little piece of thin plastic is stll in the helmet. Anyone else haveing this problem? Does anyone have a fix
    Thanks
    steve
    When all is said and done......well it must be time to ride~
    2 Stricklands, Steve & Barb
    2011 RT AC, SE5
    Trailer for Travel and/or Golf Clubs
    Power outlet up Front
    Floorboards
    Voltmeter replacing old gas gauge
    Oil Pressure gauge replacing old temp gauge
    Turn Signals on mirrors
    Very Active Member granpa in Cincy's Avatar
    Oct 2010
    Cincinnati Ohio
    Go to a fabric store that quilters frequent. They have some Velcro squares that will stick like you can't believe. You'll need to cut them to size, but they really work.
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    +2 Wipe that speaker down with an alcohol swab before trying to stick the velcro to it...
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    I too bought the Senas at Spyderfest. Very good comm set. First time I got a phone call it kinda freaked me out. "Whats the noise? I don't see no flashing lights." The phone call was virtually crystal clear and better yet, the other party understood me very well. I put the mic at the corner of my mouth and no wind noise. Someday I will get a CB walky talky and plug it into the Sena for my PGR work. Its not all bluetooth. As far as the securement just go to the hardware store and get some doublesided tape. Not sure why we need velcro if the idea is for it to stay in the helmet anyway. Whats on the back of the velcro? Doublesided tape.
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
    Oct 2010
    Cincinnati Ohio
    Quote Originally Posted by Desert Spyder View Post
    Yep. Very sticky. You better have it where you want it located in the helmet - cuz it aint gonna move very easily
    Active Member gmcgarrity's Avatar
    Plainfield,IN
    Sometimes the double sticky will not hold on the foam insert material
    I used Goop glue an they are on forever
    ride safe
    geo
