Results 1 to 25 of 31
    Jul 2011
    Coatesville, Pa 19320
    Default Replacing guages
    Since my guages don't work, I want to replace those useless guages with something else. I bought a volt meter for one, any suggestions for the temp guage replacement. Or even the volt meter.
    HELP !!!
    Sep 2011
    Johnson creek. Wi
    The volt meter is easy stuff, black wire and red wire from gauge cluster, as far as the other one I have an oil gauge, but it is only a filler for the space and not hooked up
    Jul 2011
    Quote Originally Posted by JCSMOKE View Post
    Thanks JC
    Apr 2012
    hardy va
    Default guages
    What size are the guages?
    Jul 2011
    Quote Originally Posted by antd929 View Post
    Off hand, I don't know the size, but's for a 2011 Rt ltd
    Jan 2012
    Florida
    The gauges need tone 2 1/16
    Could you stuff an ammeter in the other side to help monitor the charging situation for the battery?
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Thumbs up Hey Fonz, this is what we replaced them with on Teds Red Sled
    On the left side, a Ram Mounted Cup Holder & not that you need this on yours, but the right side has our Teddy-Cam LCD screen, mounted using a Ram Mount as well. Works for us, just thought I'd share.
    In shis pic, the cup-holder is upside down as I had just painted the speaker grills & dash bezel & was trying to get a good pic of them.20120429_111721.jpg
    But I think you get the jist. Whatever works for you my man.20120422_231757.jpg
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Quote Originally Posted by Fonz View Post
    HELP !!!
    here is what i did fonz on my 2011 Limited
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Chattanooga TN
    Default VDO Gauges
    I used digital gauges on my 2010 RT but found them too brite and distracting at night so this time I used analog VDO gauges, Voltmeter and Air Temp, and like them much better.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by cjackg View Post
    Where is the sensor for your air temp gauge? Does it seem to be pretty accurate?
    I'm curious too... (Tired of all of the popcorn!)
    Jun 2011
    Lynden, WA
    I installed a Whistler radar detector, it fits in the orgional hole. It is specifically made for motorcycles but looks like a gauge. It has a bright blue led that flashes when any of the different radar signals are detected. It also comes with a heads up display you mount on the helmut and right now they are throughing these in with the order. I think I paid about $159, but it may have been a bit less. It has a black bezel so it is perfect and, every one will do a double take when they ask what is that for? lol....
    Apr 2011
    Burlington, NJ
    Quote Originally Posted by bluestratos View Post
    Nice, how about some picts!
    Rewaco RF-1 GT
    10.57 gallons
    Chattanooga TN
    I experimented with several locations and got nearly as bad results as the oem gauge but finally mounted it underneath on the rh side just forward of the radiator and exposed to the air flow under the RT. It is very accurate there and only gets crazy when sitting still with the motor running.
    Dec 2009
    Canada
    Default Ambient Air Temperature Gauge
    I mounted a digital voltmeter gauge on the left side and a digital ambient air temperature gauge on the right side. The sensor for the air temperature gauge is mounted in the front right air intake tunnel on my RT. This position gives me the most accurate readings.
    The temperature gauge readout is accurate and it made me realize just how much the stock temperature gauge is off, especially during the summer when the combination of air temperature and engine heat can give you very high readings.
    I don't recall seeing this question addressed.
    I am happy with the temperature gauge and how it functions. Will any problems happen if I just replace the gas guage with something else and leave the temperature guage hooked up??????
    Dec 2009
    Canada
    You must disconnect both gauges for the digital fuel bars to appear on your dash screen. If you just disconnect the fuel gauge you will not have any info on the amount of fuel remaining in your tank. However, if you do not need fuel data then disconnecting the single gauge and replacing it with something else is not a problem. The analog temperature gauge will continue to function.
    Mar 2011
    Houston, TX
    Default Silly question
    Is there a way to just replace the fuel gage with a better one?
    I kind of like where it's at, there is already enough info on the little LCD.
    Boyd.
    Nov 2011
    Las Vegas, NV
    If there is, I couldn't find one when I was looking a few months ago.
    Jul 2011
    Carver ma
    Default Ambient temp gauge
    Quote Originally Posted by NorthStar View Post
    NorthStar,
    Where did you get your ambient temp gauge? Do you have a link?
    Thanks,
    Rick
    Very Active Member kinggeek's Avatar
    Jun 2011
    Cincinnati, OH
    I'm not sure that is an accurate statement. I disconnected the fuel guage on my 2011 RT and the temp guage died. I also got both fuel and temp in the digital display. Hook fuel back up, lost digital and analog temp started working again.
    Kinggeek
    Mandeville,LA
    VERY HAPPY Spyder Ryder!
    Where have we been on the Spyder? See below:
    Can-Am Spyder ST-S SE5 in Congac
    Dec 2009
    Canada
    Quote Originally Posted by kinggeek View Post
    I stand corrected. I did not know that both analog gauges had to be connected for either of the analog gauges to work. Makes me wonder what would happen if one of the gauges malfunctioned....would the other analog gauge quit working as well?
    SpyderLovers Sponsor scooterexpress's Avatar
    Mar 2012
    ft-worth texas
    check ut www.prosportgauges.com this is where i got my volt and oil pressure from wired them for red display cost w/shipping 145
    Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
    Jul 2011
    Quote Originally Posted by CyncySpyder View Post
    Yo Cincy, what do you use the lcd screen for ? I like you're style, you're out there. Hit me back how you hooked it up, and where you picked the screen up
